Help analyze my engine
Old Jan 4, 2008 | 12:02 PM
lr172's Avatar
lr172
Jackson,
Thanks for the advice. I will try to weigh the parts to find the closest match. can I swap the whole Piston/Rod combo or should I weigh and swap just the rod?
Also, do you think I will have a problem pressing out the Pin with a vice or will I need a stronger press?
Thanks again for your help.
Old Jan 4, 2008 | 12:07 PM
lr172's Avatar
lr172
Originally Posted by Little Mouse
Don't skip the machine shop check on your parts, I know what your thinking this is a running engine when I took it apart. There are a lot of good reasons to have the shop look stuff over I'm just going to mention one, having a few thousands more clearence in the bores if you were to just try and hone the cylinders is not ideal but won't hurt the rings are still going to seal every thing will still be going up down Ok. but what is a big deal is the sizing on your big end of your rods and the rod journals.You need to have a shop with the proper tools machines do that and your going to need new rod bolts.
Thanks for the nudge here. I was hoping to do this myself, but you raise good points. I did carefully measure all of the journals and they came up very clean and consistent, with no out of round or taper either. The rods scare me a bit here.
Does anyone know a good machine shop in Chicago?
Old Jan 4, 2008 | 12:51 PM
Little Mouse's Avatar
Little Mouse
What did you check the crank with ?? At least take your rods pistons
to a machine shop, You don't know how many times the rod bolts
have been torqued and streched, $ 60.00 bucks for new rod bolts
and what ever the machine shop charges for resizing is cheap insurance. Let them check your rods all out first before buying the rod bolts ARP is a good brand for rod bolts.
Old Jan 4, 2008 | 01:12 PM
lr172's Avatar
lr172
I measured the journals with a mechanical calipar in several different degrees and across each journal. I realize that the actual measurement tolerance could be off with a calipar, but the consistency from measurement to measurement should be accurate. Each journal measured where it should and with 0 deviation across the different journals. I had also plastigaged several rods and mains to check oil clearance. Each came up about .003.
I heeded your advise and called a machine shop. I am thinking of getting new rods and pistons and honing from 30 over to 40 over. They could check over the block and crank at that time. This would also let me pick a compression ratio that I like. He said that I could get new rods for about the cost of bolts and labor for tearing them apart. I will likely need 1 new piston and possibly one new rod anyways.
Old Jan 4, 2008 | 01:32 PM
Little Mouse
I would keep the GM rods if thats what they are before buying
something like the cheaper low grade chinese stuff. hes probably talking about a $300.00 set of 5140 grade chinese steel rods.
Old Jan 4, 2008 | 01:59 PM
Little Mouse
Sent you a PM.
Old Jan 4, 2008 | 10:48 PM
Little Mouse
Your PM box is full trying to send you a message.
Old Jan 5, 2008 | 01:34 AM
lr172's Avatar
lr172
cleaned up now
Old Jan 5, 2008 | 09:51 AM
jackson's Avatar
jackson
Suggest you have pro at shop press any pistons.
Easy to wreck piston / rod if you don't do it right ... damage you may not notice but would kill a fresh build.
Old Jan 6, 2008 | 08:27 PM
lr172's Avatar
lr172
Thanks for the advice. I am going to shop on Monday to have them check everything out. I will have them press it off/on. I am fairly certain the #7 piston is shot in the pin bore because the pins were pressed in improperely.
These pistons have two separate pins pressed in from both sides. I can see the gap between the two pins. Is this irregular or unsafe. I have not seen this in any of the books that I read.
Old Jan 6, 2008 | 10:44 PM
lr172's Avatar
lr172
I honed the cylinders and cleaned the block this weekend. The bores cleaned up pretty nicely. There were a couple of wears spots that did not get any real contact with the hone. They are fairly small and thought I would let them go. Would you guys take a look and let me know your thoughts?
Old Jan 7, 2008 | 10:55 AM
jackson's Avatar
jackson
I can rarely tell much about bores from pics on net/email ... I just can't see it clearly enough to really know ... so I'm guessing those bores don't look good.
Also ... too bad you didn't put up pics of 2 pins in each piston ... could be those are wrist pin "buttons" for a floating pin ... I'm guessing since I cannot see it at all.
I've never seen any motor with 2 separate wrist pins ... but I have seen a floating pin with a button on each side. I've never seen a pressed pin with buttons but I guess it's possible ... I guess. And ... there could be buttons with spirolocks beneath ... who knows? Hopefully your shop will inspect & measure closely ... & will shed much light on this & guide you. Let us know what the shop finds, measures & suggests.
Old Jan 7, 2008 | 03:03 PM
  #33
lr172's Avatar
lr172
I'll post a pic of the pins. I saw a burned spot on one, but didn't know what to make of it at the time. I now believe the mechanic/hack, cut the pin in half (hence the burn) and pressed in from both sides. I just can't figure out why. Here is a pic:
What is the best way to asses the condition of my bores. I checked the taper with an old ring and the ring gap only changed .001 from top to bottom, checked in several places. The piston to cylinder gap was tight with a .004 feeler. The book said .0045 is the limit. I don't like the scratches, but they are very thin (fingernail won't catch). Any ideas on checking of the bores? I will try to make a bore gauge and check for out of round.
I read a book that said cast rings seal better than Moly when the bore is not perfectly straight. Have you heard this? I don't mind going with cast rings.
Old Jan 7, 2008 | 10:06 PM
  #34
lr172's Avatar
lr172
Ok. tonight I fabricated a bore gauge. I took a small welding rod down to exactly 4.279). I then used feeler gauges of different sizes to measure a couple of bores. I came up with:
parallel with Crank: 4.282 @ top / 4.2815@ bottom of ring travel
90* to Crank: 4.283 @ top / 4.282@ bottom
Is this enough to warrant a bore 10 over?
I will bring it to a shop for final meaurements, but I am trying to see what type of pistons I can work with. There are more avilable for 30 over than 40 over.
Thanks.
