suspension painting
Jan 6, 2008 | 07:27 PM
suspension painting
I'm going to start pulling apart the front suspension and want to clean and paint the control arms. Are you guys using POR 15 for this or just a rustolum type of spray paint?
Jan 6, 2008 | 07:29 PM
I used rustoleum two years ago, some parts sprayed, some brushed. So far holding up well.
Jan 6, 2008 | 07:48 PM
St. Jude Donor '07
Powdercoating is a good option.
Jan 6, 2008 | 07:50 PM
St. Jude Donor '08
doing mine too. Rustoleum! Starts looking bad, hose it off, respray....
Jan 6, 2008 | 08:12 PM
The A-armss are powdercoated, the rest of the components are POR-15, top coated with Semi gloss black spray paint.
Jan 6, 2008 | 08:53 PM
I used RustBullet with a topcoat of Eastwood Chassis Black for my control arms. I did the frame with RustBullet topcoated with Rustoleoum Satin Black, but I think the Chassis Black adhered better to the RustBullet. I like the sheen of the Satin Black better though.
Rick B.
Jan 7, 2008 | 12:19 AM
red oxide primer, then two coats of rustolium, works beautyfully
Jan 7, 2008 | 07:03 PM
thanks for the replies! I wasn't sure if the rustoleum wouldn't chip off easy.
Jan 7, 2008 | 10:00 PM
I did mine with Rustoleum, came out great and is holding up really well.
Jan 7, 2008 | 10:07 PM
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Quote:
Originally Posted by
I'm Batman
Powdercoated the upper & lower control arms, Steering knuckles, caliper mount plated and tie rod tubes.
$59 powder coating gun from Harbor Freight and a $25 used oven.
