My 406 Build (w/PICS)...
400 - "511" block (+0.030)
H-Beams
Forged Flat Tops
Steel Crank
Cam - to be .480 lift w/flat tappet
http://i96.photobucket.com/albums/l1...h/DSC01420.jpg
http://i96.photobucket.com/albums/l1...h/DSC01418.jpg
Here's the top end.
AFR's - 195's & 75cc
Edelbrock RPM Air-Gap
1.6 rollers
http://i96.photobucket.com/albums/l1...h/DSC01369.jpg
http://i96.photobucket.com/albums/l1...h/DSC01372.jpg
Holley 110 gph fuel pump
Hamburger Oil Pan
http://i96.photobucket.com/albums/l1...h/DSC01389.jpg
All new fasteners
http://i96.photobucket.com/albums/l1...h/DSC01373.jpg
Mating up with a newly rebuilt 3:70 rear end
http://i96.photobucket.com/albums/l1...h/DSC00715.jpg
Let me know your thoughts, I still need help with the carb selection.
Eddie
http://www.arp-bolts.com/Catalog/Cat...talog_0049.pdf
I didn't go with the roller due to $$$. The builder originally mis quoted me at add'l $500 but quickly called me back once he started ordering parts. I know there are ALOT of opinions, but is there a cam that really stands out for this build? Or should I at least go with the RPM?
Here are a few more pics...
Rebuilt T350 tranny with shift kit & 2400 stall
http://i96.photobucket.com/albums/l1...h/DSC01421.jpg
Couple updated pics of the front end & rear with the body off...
http://i96.photobucket.com/albums/l1...h/DSC01422.jpg
http://i96.photobucket.com/albums/l1...h/DSC01423.jpg
I did things a bit backwards from the original pic, I didn't plan on removing the body but as many of you know, that's how it ended up.
Let me know your thoughts about the cam...
Does your engine builder do allot of engines for motorhomes ?
Motorhead is right. You don't want to build a tow truck engine and stick it in a sports car.
Next step up would be a Comp Cam .507/.510 lift and 240/246 @ 050 but I will need a 2800 stall. Also, the bigger I go, he mentioned that I may need more vacuum.
There is a balance between "optimal",and "acceptable" that will vary depending on who you ask. Help desk tech's are coached to under cam,in an effort to please the masses. Most folks will be happy with that advice.I went down this road myself,and after going with the Comp XE-274,which had 230@.050 duration,found the idle bone stock smooth,and ran out of power just over 5500 rpms.
I flattened a lobe,and had to re cam anyway,so I then went with the next step up,the XE-284,and ran 1.60 rockers.Pulled to 6000 rpms or so,not a bad idle.This still running a 2200 stall and idling at 650 in gear,which is lower than needed,but had that fender shake thing going on that I liked.
and whats up with the sway bar mounting links? Is that the way they told you too mount it?
As for the cam, I may be a day late and a dollar short. Engine is done and I will be getting it tommorrow. I'll post some pics over the weekend.
Regardless of what you use, cam lobe to rod clearance MUST be checked (it really should have been done longe before the shortblock was put together) and the rods clearanced as required. Check them all, but 1,2,5,6 are the ones that get close to cam lobes from what I've experienced. Flat tappets tend to have less clearance issues (duration of time the rod and lobe are near one another) than a roller profile. Best of luck to you.
That's the XE274H, which works well also. What was the .480" cam that your builder was talking about? There isn't a "magic" cam for your engine, but what you choose will determine the engine's character. Too small, like a stock factory 400 cam, will make the engine a monster from idle but it will flatten out after 4000 or so, too large and it's a turd until it hit's 4500 then it will take off, until it hits the induction restriction. Similar cams from different manufacturers aren't going to act all that differently. If you install a cam that centers the bulk of it's torque/HP production around the 2500 to 5500 powerband you will have an engine that doesn't sound "full race" but you will have an engine with excellent throttle response and will pull hard from a dead stop to 6000.
http://i96.photobucket.com/albums/l1...h/DSC01429.jpg
http://i96.photobucket.com/albums/l1...h/DSC01430.jpg
http://i96.photobucket.com/albums/l1...h/DSC01432.jpg
Alot different from what I took out of her...
http://i96.photobucket.com/albums/l1...h/DSC00536.jpg
The Hamburger Oil pan did fit, looks like I have about 3/8" clearance to the slave cylinder. I need to buy some Valve Covers (probably the fabricated aluminium ones) and then on to the Jet-Hot Coated Super Comp Headers & side pipes. Anyone have any pics of these?
I did have a few lessons learned; make sure the torque converter is "fully" seated in the trans & keep the engine mounts "loose" on the block so it has a little play before setting home.
Thanks again for all the input and let me know what you think.
