Wheel studs
Old Jan 3, 2008 | 07:02 PM
82Red's Avatar
82Red
Default Wheel studs
I got set of wheels with 4 1/2" backspacing. They are 1/2" further in than the stock 4" backspacing that the inside of the rear tires touch the tips of the rear leaf spring. I got 1/2" wheel spacers to push the wheel out. Now I need longer studs.
Can someone tell me if the specs on these studs I found on Ebay work?
How much work is there to replace the rear wheel studs?
Thanks!
RON
12x1.5 thread
2 1/4" in total length
knurl diameter is .504"
knurl length is .340"
head diameter is .615"
http://cgi.ebay.com/ebaymotors/ws/eB...121836968&rd=1
Old Jan 3, 2008 | 07:18 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Spacers aren't a very safe solution, especially with super-long wheel studs. Much better is to install bolt-on adapters. Your old wheel studs hold the adapter down, and the adapter has new studs spaced between the old ones. Long 7/16" studs spaced out like that would be ripe for breakage. Non-hubcentric wheels would make that even worse.
I'm not sure if the metric studs would require drilling to fit. I installed 1/2" studs when I had everything apart for the benefit of the much greater strength. Drilling the holes square is quite tricky unless you have something like Norval's jig.
Why do you want to go with a Metric thread anyway? Moroso has good SAE thread studs available for a quite inexpensive price through Summit's website.
I have no idea what years might have used an M12 stud from the factory, but it sure wasn't a C3. I'm pretty sure C4s used 1/2" studs for all years. "Compatible with stock lugnuts" - maybe, but not for any Corvette I've worked on.
Old Jan 3, 2008 | 08:27 PM
82Red's Avatar
82Red
Thanks for your reponse. All I know is that I am looking for studs that are the same a stock, but 1/2" longer. I have no idea what the stock thread and diameter is. Does anyone here know what it is?
Old Jan 3, 2008 | 08:54 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'm not positive on the stock length or the length of the knurled portion, but the thread is 7/16 (I think coarse). I'd think carefully about spacing anything out on the stock 7/16" studs - they're dinky enough as it is, and they were designed for hubcentric wheels (stock steel and aluminum wheels fit tight to the hub so that it's carrying a lot of the vehicle weight, not the stud). I upgraded to 1/2" studs because my aluminum wheels aren't hubcentric and I didn't want a wheel running away from me. Safety first.
Old Jan 3, 2008 | 09:18 PM
Solid LT1's Avatar
Solid LT1
You want a knurl diameter of 0.580 for direct replacement. I think they had a 0.508" diameter so they are too small. I drill my hubs and spindles for bigger studs in a Bridgeport mill and the job SUCKS! Maybe there is a metric alternative to this but, I haven't found one.
Old Jan 3, 2008 | 09:28 PM
Solid LT1's Avatar
Solid LT1
Summit has some 12mm ARP stuff for Mazdas and Dodge Neons while not that much bigger than our 7/16" stuff the ARP material is the BEST! One set was 2.45" long now you just have to find 12mm lug nuts, wheels can certainly be a BI**H! on our old cars at times. Look for ARP wheel studs and find the right knurl diameter (0.580") for your Vette. The Mazda is 0.579 and the Neon is 0.585" so either should work. There is one area that can cause problems, our rear parking brake hardware/shoes can hit on the head of the stud so you may still have some fabrication work to do on the conversion. Make sure you get 20 studs as one kit only has 4 per package.
Old Jan 3, 2008 | 09:36 PM
82Red's Avatar
82Red
Hey thanks for your response. I think I found what I was looking for at Jegs:
http://www.jegs.com/webapp/wcs/store...10002_30662_-1
Might be a little long in length considering that I really just need an extra .5". I'm not sure what the stock length is.
Old Jan 4, 2008 | 12:43 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Try doing it with a 1/2"-drive hand drill.
Old Jan 4, 2008 | 08:42 AM
Zychron's Avatar
Zychron
The stock studs are 7/16-20 (fine thread). They are 1.75 long. You should be able to find 2.25 long studs at a NAPA (Balkamp) or anyone who sells Dorman products.
Most of the Jegs and Summit studs are extra long because some racing rules require open lug nuts and full thread engagement (studs are long enough to be seen).
Old Jan 4, 2008 | 10:59 AM
rponfick's Avatar
rponfick
If the spindles are still installed on the car, I think you will have a problem installing longer studs.
I had to really work to get standard length studs in. Had to cut away at the dust shield and then still a tight fit between spindle flange and brake backing plate.
Good luck. Ralph.
Old Jan 5, 2008 | 03:46 PM
82Red's Avatar
82Red
Default Wheel stud removal
Thanks for all your help guys! Well I was finally able to find the wheel studs I needed. Now I am trying to figure out how to remove them - not enough space in the back to puul out. Are the dust covers removeable, or do I have pull out the entire spindle assembly? Which is the easier way? Ralph, what was your experience drilling out a hole in the dust shield?
Also how do I turn the axle? Should both wheels be off the ground?
Old Jan 5, 2008 | 05:21 PM
rponfick's Avatar
rponfick
I took my 1/4"high speed grinder/carbide bit, and ground a hole about in the 6 oclock position, large enough to get the old stud out and slide in the new one.
Unfortunately the rear dush shield is not removable without taking the spindle assembly apart. Good thinking GM. Actually, my dust shield was so rusty and disreputable looking that I took my tin snips and cut it off all the way around. My grinding slot was fairly easy to get to with most of the shield removed. My bearings had been previously rebuilt and were good and I didn't want to take the whole thing apart. Why somebody put the crappy dust shield back on is beyond me. I understand the dust shields are not than necessary, especially with the tender driving most of our cars get.
To Wheel studs
