headlight switch
Old Jan 5, 2008 | 12:13 PM
tarheeljww's Avatar
tarheeljww
Default headlight switch
Are they all the same manufactor?
I ordered one from Ecklers last year and right out of the box it was a piece of crap, would not hold vacum. After working on it, I managed to get it to work, but only on it's terms, { maybe it was female}
I am removing my steering column and now seems to be a good time to replace it again, but want the best part as it's a PITA to get back to it...
Thanks,
Jw
Old Jan 5, 2008 | 01:13 PM
guappy's Avatar
guappy
You might try your local Chevy Dealer to see if it's still in stock,but most of them should be the same you probally just got a bad switch
Old Jan 6, 2008 | 12:08 AM
Doc Rebuild's Avatar
Doc Rebuild
You can forget GM. Regardless of the C3 year, both of these switches were discontinued several years ago - actually PttCF (= Prior to the CF) There are 3 repro's; one using the old Delco source and two newer imports.
Geoffrey Coenen
PS I don't make these.
Old Jan 6, 2008 | 10:54 AM
tarheeljww's Avatar
tarheeljww
thanks for the info Doc, can you sugest one over the other? repo or GM and how do I know which is which?
Also, can you tell me what size the vacumm lines are in mm as I'm thinking about using a colored silicone line. they come in 4,6and 8.
Thanks again,
Jw
Old Jan 6, 2008 | 10:58 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I keep trying to tell you guys to stay away from Ecklers. It's not the company it once was.
Old Jan 6, 2008 | 11:03 AM
78Vette-SA's Avatar
78Vette-SA
Ecklers and most of the others are garbage. They should refund anyone who bought them.
Call www.contemporarycorvette.com and see if they have any originals from a wreck.
Old Jan 6, 2008 | 11:16 AM
tarheeljww's Avatar
tarheeljww
I would agree, with your accessment, as over the past three years I have noticed a decline in quality and service, but they are convienent, as I live an hour away, I get parts the next day......
Later,
Jw
Old Jan 6, 2008 | 11:25 AM
Jud Chapin's Avatar
Jud Chapin
Later,
Jw
Yep, I couldn't agree more as I live in West Palm. I used to attend their October shows which I truly enjoyed, but no more.
Old Jan 6, 2008 | 03:51 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Geoffrey Coenen
Is there any easy way to tell if the switch is from the Delco source?
Old Jan 6, 2008 | 06:47 PM
kansas123's Avatar
kansas123
Thanks,
Jw
I have a switch from my '72 and know that it works if you are interested; I don't know where it was made, came in a plain white box and I don't remember from where I bought it.
To headlight switch
