Power Steering Pump wiggle
Old Jan 5, 2008 | 06:33 PM
bytor's Avatar
bytor
Default Power Steering Pump wiggle
I'm tracking down a minor vibration and disconnected the PS pump to rule it out and noticed I could 'wiggle' the pulley and shaft quite a bit. I suspect this is not normal correct? Time for a new pump I guess. I took it for a spin with the pump still disconnected and didn’t notice any major difference in the vibration intensity.
Old Jan 6, 2008 | 09:11 AM
JimT's Avatar
JimT
The wiggle may just be a bent pulley. Many people remove the PS pump pulley by prying from the rear instead of using a proper puller. This tends to bend/warp the pulley, thus causing a wiggle. Remove the pulley then check the shaft for excess movement. I just changed mine because the previous owner/mechanic had warped it.
Old Jan 6, 2008 | 01:23 PM
bytor's Avatar
bytor
The previous owner replace the pulley so it's new and straight. I can grasp the pulley and move it back and forth. When I do this, I hear a clunking sound at the read of the pump.
To Power Steering Pump wiggle
