Need Help With This
Old Jan 6, 2008 | 06:27 PM
nastee383's Avatar
nastee383
Default Need Help With This
I'm having a starting prob with my car. About nine of ten times when the key is turned the starter pinion will extend but it won't turn the motor over. If I keep doing this it will eventually start right up. The battery was fully charged and I had it load tested. Test was good. Any thoughts on what may be going on?
Old Jan 6, 2008 | 06:35 PM
Durango_Boy's Avatar
Durango_Boy
Sounds like the starter. Get under the car and tap the starter can with a hammer. Then try, and see if it fires right up.
If you say the pinion extends then the switch is working and it's getting the start signal. The solenoid may be the culprit.
Old Jan 6, 2008 | 06:47 PM
battjke's Avatar
battjke
It could also be a bad ground wire/connection.
Old Jan 6, 2008 | 07:12 PM
'75's Avatar
'75
When you engage the starter the solenoid will extend the starter drive (pinion) and force a copper washer to the internal contacts of the positive cable and the internal terminal that goes to the starter motor to make it spin. Commonly that washer will become burnt over time and not make a good connection to the motor. Therefore the loud click, the solenoid moving the drive or "bendix" toward the flywheel but the starter motor not actually turning. New starter will fix that. But as stated earlier, a bad ground or bad positive connection could have caused the arcing( burning )of the copper contact washer in the solenoid.
Old Jan 6, 2008 | 08:55 PM
nastee383's Avatar
nastee383
If that happens over time it may not apply because the starter is brand new. I'll check the wiring. I know the connections at the starter are solid. I checked them. Maybe its a wire prob elsewhere.
Old Jan 6, 2008 | 08:58 PM
nastee383's Avatar
nastee383
If it turns out to be the starter I'll be PO'd. Its a new starter but its been in the box for over a year. So...
nastee383's Avatar
nastee383
I'm gonna recheck the wiring. Thanks
Old Jan 6, 2008 | 09:46 PM
VettePower's Avatar
VettePower
If it is indeed new, and you just put it in...It may be a shim problem.
Old Jan 7, 2008 | 08:14 PM
nastee383's Avatar
nastee383
I thought if it were a shim problem there would be grinding. The pinion comes out and hits the flexplate but doesn't spin (most of the time). Apparently there are times it meshes and turns because the car will start right up. I'll go back over all the clearance instructions and recheck everything.
Thanks, Ced
Old Jan 7, 2008 | 08:36 PM
VettePower's Avatar
VettePower
It would grind if it is overshimmed. If you have too little shims it will engage and bind.
Old Jan 7, 2008 | 08:58 PM
dannyman's Avatar
dannyman
Check both of the cables from the battery, not just the connections. Check the cables for swelling inside the shielding which would indicate corrosion is taking place. Replace if damaged.
To Need Help With This
