From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Yep....it is tight. It will seperate though. I think I used a round punch / hammer to partially collapse the tube that goes into the pump. Then you will have to "repair" and tack weld onto the new oil pump. Be sure you check the angle ... I just eyeballed mine and had to re-do after I realized it was against the oil pan.
