??'s BFG R1's
Old Jan 6, 2008 | 06:38 PM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Default ??'s BFG R1's
First question...anyone running BFG R1's for Autocross/track lapping?
Second questiion...What's your opinion of performance/wear over Kumho 710's, Hoosier R6's, A6's, and Nitto 01"s?
Old Jan 6, 2008 | 07:00 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
If you do not get any replies here, post over on the C3 side. They seem to have more modified vehicles over there.
Old Jan 6, 2008 | 07:30 PM
NMsharkracer
I did post under c_3's...????
Old Jan 6, 2008 | 10:24 PM
69autoXr's Avatar
69autoXr
Jack, although I have no experience with the new R1's, and haven't seen anyone using them at autocrosses, my understanding is that they are more of a track tire along the lines of the R6. I would expect in autocrosses that they would not be as competitive as an A6 or V710 would be. GRM magazine tested them in the November 07 issue, and they were about three-tenths behind the Kumho and Hoosier in autocross testing. As expected, they faired better when tested on an "open track" (nearly the course as the autocross but simplified a bit, and run for ten consecutive laps) when they had more heat in them, but still finished third to the Kumho and Hoosier (A6) respectively.
Old Jan 6, 2008 | 10:27 PM
Sky65's Avatar
Sky65
Woops!!!!
I've been jumping between C2 and C3. I guess I lost track of where I was! Sorry.
Old Jan 6, 2008 | 11:09 PM
gkull's Avatar
gkull
I prefer real slicks, What size rims are you going to be using? I have used The 710's, for a lapping weekend. Most people get about 7-10 events out of a set in mildly modded cars. I'm talking about 20 - 30 minute run groups.
I just bought 6 hoosier slicks for my rears for $550 delivered,. They are once used scuff tires with 95% tread. They are 27X11X15
I would just buy some cheap wheels and slicks for your events. Slicks have so much more traction than treaded tires.
Old Jan 6, 2008 | 11:48 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If memory serves me correctly, I believe he's looking at 9.5x17's and 11x17's.
Old Jan 6, 2008 | 11:55 PM
gkull's Avatar
gkull
Then I would buy, the 710's in 275 or 295 front and 315 rears
The tire rack has some close out prices for about $200 each. I'm getting these knockoff slicks for $75 each plus shipping
Old Jan 7, 2008 | 07:30 AM
NMsharkracer
Chris,
Here's my problem, Two of the courses we run autocrosses on early in the year are airports with very rough concrete. Last year with both me and my girlfriend racing, we corded a set of A6's in one weekend. This gets expensive. Kumho's in the sizes I need aren't going to be available until sometime in march and their new compound is supposed to be more like A6's. This leaves me with either R6's or BFG's and I so I'm looking for some advice and/or experience on them.
Old Jan 7, 2008 | 07:33 AM
NMsharkracer
[B]Gkull[B]
I'm running 9.5x17 fronts 11x17 rears. Tire diameters are approx 25.5. I wanted to go to Kumho's this year but they are re compounding and won't be available until March.
Old Jan 7, 2008 | 07:35 AM
NMsharkracer
And a good memory you've got. It's good to see celebrating Redman's cat has not done you in
Old Jan 7, 2008 | 08:35 AM
69autoXr's Avatar
69autoXr
Chris,
Assuming you corded the outside of your fronts; how much camber are you running? I ran a 12-event weekend (27 runs total) at Grissom in Indiana in October on my half-worn A6's-Grissom is very rough concrete as well-an then the tires corded at the next event. If I had been smarter about flipping my tires I'd probably still have some life left on them. My point is, I have experienced very good wear out of the two sets of A6's that I've had, with over 100 runs on boths sets. I run about -2.5 degrees in front and -2 rear.
The only two times I've autocrossed on my R6's it was awful. Two drivers would help your situation however.
Old Jan 7, 2008 | 08:38 AM
gkull's Avatar
gkull
[B]Gkull[B]
I would check the tire rack.
Old Jan 7, 2008 | 08:50 AM
NMsharkracer
Camber before winter mods was -2.0 front, -1.5 rear. We corded the inside of the right front. Combined, we did about 30 runs that weekend on a 1.1 mile course that was run counter clockwise. Rechecked alignment after the event and it was right on. Tire Pyrometer didn't work and with the constant driver switching we had to do it was difficult to do anything but change seat positions and belts. Maybe I had a bad tire to begin with, just a little leary of the A6's.
Old Jan 7, 2008 | 10:25 AM
gkull's Avatar
gkull
To cord the inside of the front. Is too much camber or are you running a toe out alignment spec.
Old Jan 7, 2008 | 10:47 AM
NMsharkracer
Yes, we were toed out about 1/8" total. There were a lot of transitions on the course and I hadn't done anything with bumpsteer, something I'm addressing this month. It just seems that our settings weren't excessive to cord a tire in one weekend.
Old Jan 7, 2008 | 10:59 AM
gkull's Avatar
gkull
I use less than 1 degree neg camber because I have destroyed the inside before. I went into the pits last year after a wild spin off the road to cool bleed my brakes. I had not only flat spots but had corded the inside of both my front tires. The marginal gain in cornering speed is probably negated under straight line braking where it has nearly all the weight on the inside of the front tires. I had 5/16 tread depth on the ouside and cords on the inside.
Old Jan 7, 2008 | 11:49 AM
69autoXr's Avatar
69autoXr
The Hoosier DOT radials like more camber than less. Maybe brake lockup was an issue? Or understeer? Right now without bumpsteer correction or super stiff springs I do not run toe out; as the outside front leans into a corner it toes out more. I actually use toe-in, about 1/8" total.
Old Jan 7, 2008 | 06:23 PM
NMsharkracer
Chris,
I think a combination of bumpsteer with the relatively soft (550#) springs, the toe out, and a lot of hard braking all contributed to the tire wear. I probably will go with another set of A6's unless Kumho get's there act together and delivers tires. My girlfriend raced my Rippie built '93 for a couple of years and got used to the ABS helping her during braking. She still is working on learning "old school" In the mid 90's, she was one of the fastest women in the midwest so I can't give her too much grief, but I do show her the tire bill!
I've got some Guldstand springs coming for the front and will be working on the bumpsteer as soon as I can put it all together.
For shocks, I'm running Bilstein "Sears Point" shocks. I'm considering going to Koni adjustables but haven't yet because it adds one more variable.
Our first event out here is next month in Phoenix. I'm really going to be scrambling to get it all back together by that time.
Thanks for your input...Jack
To ??'s BFG R1's
