I took my car out for a 2hour drive on HWY(9) and on the way home I was getting kick backs on my rpms @2,500. I checked my oil and spark plugs but they seem okay. Has anyone had this problem before?
1. Replace the fuel pump with a newer model, I think 87 which pushes fuel well above the 12~14 PSI needed.
2. Installed the fuel pressure gauge kit from DCS and adjusted my fuel pressure to 13ish.
3. Balanced the throttle bodies using a nanometer.
Runs great and idles smooth. I used to get stutters and lack of power at various times. The fuel pump sock I pulled out was just a mess and obviously that material was being pushed through the lines.
