Transmission
Old Jan 8, 2008 | 11:01 AM
jib80's Avatar
jib80
Default Transmission
I was thinking a 80 vette L-48 came with a Turbo 350 Transmission, but have been told by a few other owners of the C3 years that they very. Just wondering what would compliment a 383 stroker motor more effectively.
Old Jan 8, 2008 | 11:22 AM
SIXFOOTER's Avatar
SIXFOOTER
It will be either a TH350 or a TH400 depending (dunno on what)
General consensus is a TH2004R, its got a better gear set and overdrive. Can be built for hot rodding for about $1000, only a little more than a 350 or 400 and it has advantages over both.
Old Jan 8, 2008 | 12:36 PM
BKbroiler's Avatar
BKbroiler
The Turbo 350 was the only automatic offered in an 80 Vette.
I have one behind the 383 in my car.
Old Jan 8, 2008 | 01:14 PM
7T1vette's Avatar
7T1vette
If your version of the THM350 is an overdrive model..and your 383 build is not a "super powerhouse" build up, just use what you've got. If your engine is putting out more than 350 hp at the wheels, you might want to consider installing a beefier transmission (200R or 700R).
Old Jan 8, 2008 | 01:21 PM
45ACP's Avatar
45ACP
80 and 81 C3s with automatics were all born with a 350C which, basically, is the good old 350 with a lockup torque converter added.
To Transmission
