I would like to replace a side window. I have the GM service manual and it mentions removing the two shash nuts. It looks like you would also have to remove the upper stop on the front track to enable having
the front roller slide out with the window. Do you also have to remove the outer window seal to gain more clearance?
After removing the shash nuts do the bolts then slide off the horizontal regulator channel?
Any suggestions on how to do this would be helpful.
got mine all apart now 81. yes had to remove outer seal and some major wiggling to clear the inner mirror bracket
