1969 headlights dimming???
Old Jan 8, 2008 | 10:07 PM
mike livelsberger's Avatar
mike livelsberger
Cruising
Default 1969 headlights dimming???
Tonight I took the car for a drive and stopped for gas. It was getting dark so I turned on the headlights. The interior lights were all normal as far as brightness. On the dash the brights symbol for the high beams came on as well as both turn signal markers, not flashing though. I progressed home and the headlights continued to dim until they didn't funtion. I hit the high beams and it gave me a little light. Before I reached home they instantly returned to full brightness and the dash returned to normal, with the turn markers going off and the high beam marker going off. As I pulled up the drive it started again. The car runs fine and the interior lights seem fine. The voltage gauge reads almost 14 volts. Any ideas???
Thanks for any help.
Old Jan 9, 2008 | 08:29 AM
Durango_Boy's Avatar
Durango_Boy
Do you have a digital multi meter? Start checking things out. Battery, test it with the engine on and off. Off, somewhere north of 12V if it's healthy. On, 14+V.
Inspect the terminals and battery cables as far as you can see them. Are the cables swollen at all? This would indicate corrosion inside the protective jacket. Make sure the battery ground cable has good connections under the car, and I would even slide under the car and check your connections at the starter.
Then, go up to the alternator. With the engine off, check for 12+V at both the red wire going to the BAT lug on the alt, and from the red wire from the alt plug. With the engine off, the brown or white wire from the plug should have nothing. With the engine on, both red wires will still have 12+V but the brown or white wire will also have 12V.
I would suspect you have a bad ground or a bad power wire connection. Past that, the regulator or diode trio might be going out in your alternator and it's an intermittent symptom.
Old Jan 10, 2008 | 01:47 AM
mike76c3's Avatar
mike76c3
Default Check the High Beam Switch too
I had something similar happen. Don't know that I had ever used my high beams before, but one night I did, and my lights acted like you described. Was doing some research in the archives, and found a thread that said to check the High Beam Switch. Yup, mine was bad; had even melted the plastic connector
Mike
Old Jan 10, 2008 | 11:25 AM
SIXFOOTER's Avatar
SIXFOOTER
I think if everything else was working fine and you had 14v on the gauge you can skip the battery and alternator and go directly to the headlight switch circuit. If it looks ok, then go thru the grounds for the headlights, make sure they are solid.
Having said that, its never a bad idea to look over the battery and alternator connections. I just don't think thats where your issue will be.
Old Jan 10, 2008 | 12:18 PM
sly vette's Avatar
sly vette
I vote for a bad ground
S489's Avatar
S489
also check the one little 14 ga ground wire connection for all lights up front. should be located near bottom front of rad support. could be corroded
Old Jul 6, 2008 | 09:46 PM
mike livelsberger
Cruising
Default Bingo!
Fixed it a while ago, just didn't get to post right away.
Sure enough. A loose wire connection on the radiator support. I remedied this retapping the hole for a larger screw and by adding another wire to it and running it to the motor/frame. Works perfect. Thanks for the input.
Old Jul 7, 2008 | 11:46 AM
wattac2's Avatar
wattac2
You may want to look a bit further. That #14 on the radiator support isn't for the lights. All headlights get their "ground" returns via a wire inside the harness that runs back to the alternator. At least that's what the wiring diagram shows.
To 1969 headlights dimming???
