Repainting Steering Column ?
Old Jan 8, 2008 | 10:29 PM
Ray Y's Avatar
Ray Y
Default Repainting Steering Column ?
I haven't pulled the AIM to research this yet, but is it a PITA to remove the steering column to repaint it or should I just mask everything and spray it while still in the car? Everything is currently out of the car except the steering column.
Do you need a wheel or gear puller to remove the steering wheel or any other special tools to get the turn signal and ignition switch components out?
Got 2 boxes in from ZIP today and all of the console and dash components have been repainted waiting re-install.
Old Jan 8, 2008 | 10:33 PM
1FSTZ06's Avatar
1FSTZ06
I pulled my interior to replace everything from red to black. Just mask and cover for overspray and repaint it in place. Mine turn out great so I don't see a need to remove it.
Old Jan 8, 2008 | 10:35 PM
shoptek's Avatar
shoptek
I did mine while the dash pad was out. Mask everything. I used a Harbor Freight $5 air brush and took my time
Old Jan 9, 2008 | 07:42 AM
dobroman2001's Avatar
dobroman2001
It's not too bad to remove the column.... here's some pictures, they may help some.
http://s189.photobucket.com/albums/z...man2001_photo/
Old Jan 9, 2008 | 02:03 PM
68 NJConv 454's Avatar
68 NJConv 454
Whether you leave it in or take it out make sure you take your time and prep the column right. I bought an 80 tilt/tel column from a swap meet to put in my 68 and I guess the column had tons of layers of silicon and other crap that was a major PIA to get off for the paint to stick right. Best guess is when they put that Armorall stuff or other chemical treatments to make your interior look shiny, it really sticks to the paint & plastic and is a PIA to get off. You have to get all surface contaminents off the column before painting.
I went to the local paint store and home depot and picked up all kinds of cleaning agents to remove the silicon first.
Once I knew everything was off I light sanded it with a fine sandpaper to ensure it was all off. Don't sandpaper it before cleaning it b/c the sandpaper will just push the silicon deeper into the plastic.
After 3 attemps, my paint finally stuck and no blotches were present.
good luck.
Old Jan 9, 2008 | 02:45 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I stripped mine completely apart, sandblasted the metal housing parts and powdercoated them. Looks great, and should wear very well.
Old Jan 9, 2008 | 05:18 PM
Emeightch's Avatar
Emeightch
Hope I'm not hijacking the thread, but what paint do you guys recommend.
Old Jan 9, 2008 | 08:09 PM
dobroman2001
I used Rust-oleum semi-gloss protective enamel for the steering wheel hub and horn button... worked great for me.
Old Jan 9, 2008 | 08:54 PM
1FSTZ06's Avatar
1FSTZ06
Rustoleum in satin black
Old Jan 9, 2008 | 09:56 PM
Ray Y's Avatar
Ray Y
Thanks for the input guys. I got to spend a little time with the service manual today and I think I'll paint while in place, even though I like the idea of powder coating it.
To Repainting Steering Column ?
