LS7 in a C3
Old Jan 10, 2008 | 12:11 AM
arctic74vette's Avatar
arctic74vette
Default LS7 in a C3
My boss bought a 1968 Vette (w/o motor or tranny ) a couple of weeks ago. Weve been talking here and there on possible engine choices and he really likes the idea of having a 427 CI in it (original big block car). Ive been trying to convince him to put the LS7 in it and he finally decides he wants to and tells me that i'll b calling the shots on the whole car .
I'm needing to know what all is needed to put the LS7 in the vette. I know the list goes on and on but for now i just need to know all the necessary parts. Motor mounts, computer, dry sump??? Any and all responses highly appreciated.
Oh and i know there will be the question, Why not a built FI LS1 or LS2. The LS7 is just too freaking sweet. Gotta have it
Old Jan 10, 2008 | 12:15 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There is a thread in the "sticky" section at the top of this page that you might find useful.
Old Jan 10, 2008 | 11:02 AM
palamesa's Avatar
palamesa
Here is an example of a swap on a newer Vette. http://www.vetteweb.com/tech/vemp_06...ine/index.html
An LS7 crate motor will run you about 14K. By the time you add all the other parts you need, figure 20K. LS1's make more cost effective swaps as well as easier to adapt the F body LS1's into the C3.
Bottom line, the LS7 would be sweet if you have the budget.....gp
Old Jan 10, 2008 | 11:36 AM
Aggitated Monkey's Avatar
Aggitated Monkey
There is the sticky and also alot of threads on the LS swap. I have read most of what is available and I don't think its that difficult. Actually very straight forward. You will need to have the harness taylored the way you want and I think the AC (if you are going to have AC) is a little challange.
I have seen many of the motor mount adaptors available and they are not very exspensive. I have read that the F Body oil pan and belt drive system works the best. There seems to be some monkey motion for the lower cooling hose and you will need electric fans.
There are some proven drive shaft/crossmember mods that will be required depending on the trans (auto OD, 6spd, 5spd) you go with.
I have considerd a BB or LS for my '80 and find that the BB would be a little less challanging as there are many parts available. The LS has some challanges that I have mentioned along with PWR Steering hook up and heater hose conections.
A few members have done this and their are some viedo's with the results, including a C3/LS taking a C6 Z06 in the quarter 3 out of 3.
Old Jan 10, 2008 | 02:41 PM
Garys 68's Avatar
Garys 68
The biggest problem with the LS7 swap will probably be the dry sump oil tank.
But if you wait a few months, GM will be releasing a carb version of the LS3 that's rated 520hp for about half the price of the 505hp LS7.
Old Jan 10, 2008 | 05:35 PM
Aggitated Monkey
Great point. I completely overlooked the dry sump. I think that will create a large challange. What would be wrong with the LS1 or LS6? if its HP the 2 can be modified for an increase.
Old Jan 10, 2008 | 06:30 PM
Gordonm's Avatar
Gordonm
I'd get a LS6 for about half the price or better then bolt on a blower. You will have more power than the LS7 and it will be an easier fit. That dry sump tank and lines is a problem but it can be overcome. My brother in law had a custom dry sump tank made for his 67 resto mod with a LS7
Old Jan 10, 2008 | 07:21 PM
78Vette-SA's Avatar
78Vette-SA
You don't need to go with the dry sump unless you want. There are conversion kits out there to use a stock pan like an F-Body or LS2/3 pan.
Old Jan 10, 2008 | 08:44 PM
Speed Hound's Avatar
0Speed Hound
Former Vendor
artic,
you can build a 427 for less than buying an LS7 crate. This uses the LS7 block even. You can then use the wet sump pan if you choose to. There are many after market drive accessories that are very nice and should work fine in the car. Or you can run Fbody accessories. This is very doable even with the dry sump. But that dry sump tank will be difficult to mount if you choose to keep it.
Old Jan 11, 2008 | 04:51 AM
7T1vette's Avatar
7T1vette
Your boss has been reading "Tom Sawyer...", hasn't he? And you haven't read it.
P.S. Have fun doing all of his work!
Old Jan 11, 2008 | 10:17 AM
SuprJames's Avatar
SuprJames
Hey, there is fun in using someone else's money to build an awsome car.
If you want aluminum this is your best bet.
http://www.texas-speed.com/shop/item...d=828&catid=85
If you boss wants nitrous or forced induction then he needs to look at their other offerings.
Old Jan 11, 2008 | 10:29 AM
Garys 68's Avatar
Garys 68
For those of you suggesting a blower being a cheaper way to make 500+ hp, check out Magnachargers website for prices. They dont exactly give away those blower/intercooler packages.
Gary
Old Jan 11, 2008 | 10:54 AM
45ACP's Avatar
45ACP
But he'll also be the guy's perpetual tech support resource. "The car has a funny noise, can you come over and take a look?", etc, etc.
Old Jan 11, 2008 | 11:43 AM
arctic74vette
The reason we chose the LS7 is because $$$ is out of the picture. He has waaaaaay too much. in regards to the blown LS1-2-3 (watever it may be), we were planning on a set of HPE heads, a QM600, and some headers so it would be putting out around the same power as the FI LS. yeah I know it sux building someone elses car but i'm gonna b the one taking it to shows and driving it the most, and I'm only 19 so I'm thrilled!!! keep the responses coming
Old Jan 11, 2008 | 11:55 AM
Garys 68's Avatar
Garys 68
If you want chromed car show flashy stuff and hp, check out this combo.
LS376 (520hp) http://www.gmperformanceparts.com/En...1225&engCat=ls
And a chrome twin carb setup (PN 20684):
http://www.edelbrock.com/automotive_...old_kits.shtml
Old Jan 11, 2008 | 05:31 PM
78Vette-SA's Avatar
78Vette-SA
Gary
No but they look sweet - IMHO!
Not to mention that even with the cost of a Maggie (Hot Rod Unit), a used LS6, Decent Heads and Cam, Pulley System, you are still in for less $ than a new LS7 and making more HP.
Old Jan 11, 2008 | 06:01 PM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
An LS7 in a 68-72 with side exhaust would be killer...
Old Jan 11, 2008 | 06:15 PM
78Vette-SA's Avatar
78Vette-SA
Tell his boss he'll build this for him (Rich Lagasse's Sweet 63 coming together).
To LS7 in a C3
