383 Rotating Assemblies? Who Do You Guys Use?
Old Jan 10, 2008 | 11:19 AM
James's Avatar
James
Default 383 Rotating Assemblies? Who Do You Guys Use?
I’m getting ready to rebuild a 350 I have in a 1968 Camaro and for the cost I figured I would just purchase a 383 rotating assembly for it and make it into a 383. I have used some Eagle Specialty Products in the past and I see they make a number of different kits. This is going to be a pump gas motor and will not see any track time. I was just curious to see who you guys have used for rotating kits that have built 383’s? Also I know the difference between a forged crank and a cast crank but what do they mean when they say cast steel crank? This is just a cast crank right?
Old Jan 10, 2008 | 11:39 AM
Scott Marzahl's Avatar
Scott Marzahl
Cast steel is a "cast" crank as opposed to a "forged" steel crank from a billet. There are a number of choices, Eagle, Scat and Ohio Crankshaft seems to be pretty popular. Ohio Crankshaft was a former Dodge Viper crank contractor which says a lot for their quality. A cast crank will be adequate for most mild street builds. I've used a stock GM 400 crank turned down in a nitrous motor that I ran trouble free for 6 years before I sold it.
http://www.ohiocrank.com
Old Jan 10, 2008 | 11:46 AM
gkull's Avatar
gkull
Go down to the bottom and get one of the $1100 dollar kits
http://www.flatlanderracing.com/scatsr-chevysbcast.html
Or go down to the 3.875 stroker kit and build a 396 ci for $1400
I just got tired of breaking stuff and even had a set of KB Hyper pistons smear aluminum in the bores. So I bought all forged lightweight kits for about $3200 and have never had a problem. These lower 1100-1400 is the minimum I would use.
I also only build 396 ci stroker motors in 350 blocks because for the cost they put out the most power.
Old Jan 10, 2008 | 11:55 AM
fauxrs2's Avatar
fauxrs2
I just got tired of breaking stuff and even had a set of KB Hyper pistons smear aluminum in the bores. So I bought all forged lightweight kits for about $3200 and have never had a problem. These lower 1100-1400 is the minum I would use.
I got all my bottom end stuff from flatlander...good guys
Old Jan 10, 2008 | 12:11 PM
jackson's Avatar
jackson
James:
I don't do kits ... buy the stuff separately ... when chosen & shopped right ... you'll get what you NEED and probably save $.
Watch your compression ratio. That 68 camaro 350 may have iron heads with about 64cc combustion chamber volume. Before you proceed ... You need to KNOW what heads you're gonna use ... there's a casting number under valve cover that'll ID GM heads. If 64cc, you'll probably want deep-dish or reverse dome pistons for most street. Once you stray from 3.75" stroke (typical 383) ... and unless you spend all out on forged stuff ... costs climb when you deviate from 3.75". I don't like any cast or hyper piston mfg'd by KB or UEM ... I do like Sealed Power/Speed Pro cast/hyper. Bottom line ... 383 with cast crank & cast/hyper piston is rather inexpensive and holds up for most street / lite strip use.
Old Jan 10, 2008 | 12:25 PM
James's Avatar
James
Thanks for tips and suggestions guys!!!! A 396 might be something for me to think about too.
My motta is "No replacement for displacement"!!!!
gkull is there quite a bit more clearancing that has to be performed to get the 3.875 crank into a 350 block to net the 396CI's?
I have a set of World Products cast iron 69CC 2.055 Intake/1.60 Exhaust 200CC runner heads I could use on this motor along with some Comp Cams Retro fit Hydraulic Roller lifters. Just kind of getting started and have not put a ton of thought into the entire configuration yet but I know before I buy anything I need to make sure I have a good config in place for what I want to use the setup for.
Old Jan 10, 2008 | 12:29 PM
Glensgages's Avatar
Glensgages
Originally Posted by James
..... but I know before I buy anything I need to make sure I have a good config in place for what I want to use the setup for.
..... which-is?????
Old Jan 10, 2008 | 01:15 PM
James's Avatar
James
I guess I would maybe say a "performance street setup" ?
Old Jan 10, 2008 | 01:40 PM
gkull's Avatar
gkull
With cast iron I would limit myself to 10.2-10.5 max static compression even with a 236-242 I duration roller cam.
The difference in the amount of grinding in the forward cylinder pan rails is minimal.
I also own a 67 RS/SS 4 speed. It has a 2.73 rear end. So it's usually either bog or burn to take off. But once your moving it's all about motor TQ.
Old Jan 10, 2008 | 06:18 PM
dgruenke's Avatar
dgruenke
I got my kit from Ohio Crankshaft. I used their crank and rods, and they used Speed Pro pistons for the kit. It came externally balanced with the flexplate, balancer, all bearings, etc.
I had a few problems logistically, but they were all worked out. They were minimal. First, they sent me a crank for a 400 block. They picked it back up and cut it down to the correct size. Next, I was missing the piston pin clips. They sent them to me. Next, the piston rods were not properly cam-clearanced. They sent me another set. It delayed my project a little bit, but they were always very nice on the telephone, and promptly rectified all issues.
I have not yet fired the engine up yet, but I would not have any problems at this point recommending them.
Old Jan 10, 2008 | 06:57 PM
billla's Avatar
billla
St. Jude Donor '14
Things definitely get more interesting with a 396, including the need for a small base circle cam in some cases.
My only advice is to avoid Eagle cranks. My 383 Eagle cast crank had unacceptable taper, and I've heard of a few other experiences from my machine shop. Scat has been universally good.
As you note, it's really time to get the plan together
Old Jan 11, 2008 | 09:04 AM
PNK's Avatar
PNK
Had some bad experiences with Eagle in the past, mainly balancing issues and broken Cranks.
I only use SCAT now and they seem to be of better quality in all regards.
I have never tried Ohio Crank so i dont know anything about them.
For a performnce engine i would recommend that you go with forged pistons and forged rods, no need for a forged crank unless you plan on high rpm
To 383 Rotating Assemblies? Who Do You Guys Use?
