Aluminum Heads
Old Jan 10, 2008 | 05:19 PM
ethanm's Avatar
ethanm
Default Aluminum Heads
what does everyone think of this set of heads
http://cgi.ebay.com/ebaymotors/Chevy...QQcmdZViewItem
im on a budget so i would like the performance and reliability at a low price.
Old Jan 10, 2008 | 05:36 PM
Scott Marzahl's Avatar
Scott Marzahl
Garbage made in China heads. They do not get very good reviews in terms of quality. You can get Brodix IK180 or IK200s bare for that.
If you are tight, just get a set of Vortec heads but then again what are they going on?
Old Jan 10, 2008 | 05:40 PM
ethanm's Avatar
ethanm
see thats what i figured...well but ive already got an intake for regular heads and dont wanna spend another 200 on a vortec intake and then more for new valve covers...a 76 vette l-82...were putting a motor from O Reillys (where i work) in it and i want more power from it
Old Jan 10, 2008 | 05:45 PM
Emeightch's Avatar
Emeightch
I know where you're coming from, but I was always told that the heads are one area you DON'T want to chinse out on. I bit the bullet and went with the AFR's 195cc for my 406. $1441 @ Jegs.
Old Jan 10, 2008 | 05:51 PM
dgruenke's Avatar
dgruenke
Do a search on the forum for those heads. Awhile back, there were several threads that talked about the Pro Comp and Superflow heads from ebay.
Old Jan 10, 2008 | 05:54 PM
bruced267's Avatar
bruced267
Those heads have been heavily discussed on here before! do a search. I have bought few parts from a similar company (same location new name) and bad luck. Your half way to a set of edelbrocks save some $$ and wait a few more weeks.
Old Jan 10, 2008 | 05:59 PM
Scott Marzahl
If you are set on aluminum, I'd spend a few hundred more on a set of Brodix heads.
http://www.competitionproducts.com/p...ber=BRO1021004
Old Jan 10, 2008 | 06:14 PM
ethanm's Avatar
ethanm
http://store.summitracing.com/partde...5&autoview=sku
something like these?
Old Jan 10, 2008 | 06:21 PM
Scott Marzahl
Depends upon your build, 200 runners may be a bit large.
http://www.brodix.com/heads/ik.html
Old Jan 10, 2008 | 06:42 PM
ethanm's Avatar
ethanm
yea it will be a daily driver so it will be a basic crate motor...what about the summit aluminum heads...anyone tried them?
Old Jan 10, 2008 | 06:51 PM
69small block's Avatar
69small block
Default alum heads
you might look at patriot heads
Old Jan 10, 2008 | 06:52 PM
Scott Marzahl
Haven't heard anything about them. For the money, the IK180s will be tough to beat.
Old Jan 10, 2008 | 06:54 PM
ethanm's Avatar
ethanm
anyone had any luck with the patriot heads on ebay?
Old Jan 10, 2008 | 07:01 PM
Scott Marzahl
Just Google them, you'll find out all the hit and miss problems with them. Seems to be very inconsistent quality. More made in China junk, they say New Zealand, via China Quality is not that cheap. Your looking at $700 via $1K in a crap shoot. Just try to resell that Cheap stuff down the road.
Old Jan 10, 2008 | 07:06 PM
ethanm's Avatar
ethanm
yea i understand...i may just run the motor stock till i get out of college and start making some real money...cuz im just a senior in high school working part time so i cant drop a whole bunch but ill do some more research on some
Old Jan 10, 2008 | 07:21 PM
ethanm's Avatar
ethanm
how bout this instead...anyone put one of these in anything
http://www.jegs.com/webapp/wcs/store...0002_127626_-1
Old Jan 10, 2008 | 09:07 PM
hgm's Avatar
hgm
I have a new pair still in box 200 cc x 74 cc Dart heads w/ valves and double springs that I am thinking of selling, PM me if you are interested
To Aluminum Heads
Old Jan 10, 2008 | 09:21 PM
a1sensei's Avatar
a1sensei
I got a set of new complete Dart Iron Eagle 180cc heads on Ebay a couple of years ago for $800 to my door. I recommend them! God bless, Sensei
Old Jan 10, 2008 | 11:21 PM
jackson's Avatar
jackson
I second scott's brodix suggestion.
Keep in mind IK200 has very large ports & requires fp 1206 gasket ... and it's quite possible they won't fit just any manifold that might be laying around. IK180 has smaller ports & requires fp 1204 gasket and will fit most any manifold. Sadly, a pal ran into this very situation and had to exchange IK200 for IK180 ... No longer available were any decent manifolds that'd fit huge 1206 and a Qjet AND fit under his hood.
Nix the asian heads ... spend another $300 & get the good stuff.
Old Jan 11, 2008 | 12:59 AM
Scott Marzahl
Well that's the smartest thing I've heard yet and good for you. You should take a quick look at my latest Bog entry on my kid's motor. You two are both in the same place, seniors and broke.
So let us get this straight, do you have the stock L-82 motor? That is a good forged piece. Or are you putting a commercially rebuilt motor in it from your store? For now, you can simply put a shorter duration cam with a tighter ICL to make a little more cylinder pressure or advance the stock cam if it is still serviceable. The stock L-82 cam is nice but does better with more compression and advanced 4 degrees for more bottom end.
