New Starter
Old Jan 11, 2008 | 04:12 PM
Quick 8's Avatar
Quick 8
Default New Starter
Hello,
I just put a new 383 into my 79. It has headers and yada yada yada ... now I need a new starter.
By the way, I already tried a powermaster gear reduction starter, and it was a piece of junk!! It worked great for 5-6 starts then the starter gear would no longer stay engaged.
Per a recommendation in another post I saw, you can get a facotry gm lightweight starter by going to autozone or napa and asking for a starter for a 98 chevy pickup. Is this a good route to go?
Any input is greatly appreciated.
Thanks.
Jim
Old Jan 11, 2008 | 04:18 PM
Ironcross's Avatar
Ironcross
Yep. thats the one. Permanent magnet starter fits later model big and small blocks. About $65.00.
Old Jan 11, 2008 | 04:31 PM
Quick 8's Avatar
Quick 8
Thanks a lot. I'll go pick one up tomorrow.
At Autozone, the cheapest 1 yr warr. starter I see on their website is $84.99
For the lifetime warr. it is $99.99
-Jim
Old Jan 11, 2008 | 05:03 PM
Gordonm's Avatar
Gordonm
I have been running the GM one on mine for about 5 years now with no problems at all. No heat soak ever. Start right up under all conditions.
Old Jan 11, 2008 | 05:04 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I can't recommend that little beastie strongly enough. Sounds kinda funny, starts great.
Old Jan 11, 2008 | 05:21 PM
Surfer69's Avatar
Surfer69
Is that for 153 tooth only or 168 also?
Old Jan 11, 2008 | 06:37 PM
Quick 8's Avatar
Quick 8
I sure hope it is for a 168 tooth, stagger bolt mount, because that's what mine is.
Old Jan 11, 2008 | 06:56 PM
Ironcross's Avatar
Ironcross
It is, 168................
Old Jan 11, 2008 | 10:47 PM
SteveG75's Avatar
SteveG75
The GM part# is 9000852. This is the starter Chevy uses on the 502 big block and fits all SB or BB with a 14" 168 tooth flywheel (staggered bolts).
One note. You cannot use your stock bolts. The correct bolts are special with metric shanks and standard threads. GM part# for the bolts is 12338064 and you can get them from any dealer.
Great starter. Had mine for several years now.
Edit. Here is a picture for your reference:
Old Jan 11, 2008 | 11:26 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Steve, thanks for that bolt part #. Mine is currently held up with one of the weird correct bolts and one old-school starter bolt with about four washers stacked under it to take up the slack.
Old Jan 13, 2008 | 11:03 AM
toolman0114's Avatar
toolman0114
[QUOTE=SteveG75;1563584986]The GM part# is 9000852. This is the starter Chevy uses on the 502 big block and fits all SB or BB with a 14" 168 tooth flywheel (staggered bolts).
Just put one of these on my 74 and it works great
Old Jan 13, 2008 | 11:46 AM
carriljc's Avatar
carriljc
Default Ok, which part for the 153 tooth flywheel???
Is there an equivalent? Mine is a '68...
Old Jan 13, 2008 | 12:06 PM
SteveG75's Avatar
SteveG75
For a 153 tooth flywheel, I would use this one. Note the bolt numbers as well.
10455709 - Starter, Gear Reduction 153 Tooth L-98 Corvette Style, BRAND NEW. No core charge. This lightweight starter was introduced on 1988-95 Corvettes. Its internal gear reduction multiplies torque for fast starts. It weights just 10.14 lbs - 9 lbs less than a conventional starter. This compact starter also offers additional clearance for competition oil pans and chassis components. Use starter bolt P/N's 14097278 and 14097279.
Be careful though: Technical Notes: Use with 12-3/4” outside diameter flywheel. Pre-LT1 engines require starter machine work. All starters sold at GILBERT CHEVROLET are modified to work.
http://www.gilbertchevy.com/frame.ht...rformance.html
To New Starter
