Cams; Advertised duration vs. .050 duration
Old Jan 12, 2008 | 04:29 PM
454_71Stingray's Avatar
454_71Stingray
Default Cams; Advertised duration vs. .050 duration
Is there any conversion formula or is it completely apples and oranges?
Old Jan 12, 2008 | 04:43 PM
Gordonm's Avatar
Gordonm
Not really because some cam manufactors rate the advertised duration at .006 and some at .010 and some at random. The .050 numbers are the best to go by.
Old Jan 12, 2008 | 05:02 PM
murraybs's Avatar
murraybs
And depending on the ramp angle the .050 and the advertised can differ significantly.
Dwell over nose is an important consideration too, but only if you're going to be doing SERIOUS number crunching.
Old Jan 12, 2008 | 05:03 PM
lars's Avatar
lars
There is no conversion or relation between the two. Ramp profiles and methods of determining "advertised" numbers make that impossible and irrelevant. Just use the .050 numbers - it's the only spec that means anything and that can be compared from one cam to another.
Old Jan 12, 2008 | 05:35 PM
454_71Stingray
This is what I thought, I guess I was looking for confirmation. Trying to compare two cams from different manufacturers and two different sources, Jegs typically displays 'advertised duration' and Summit displays '.050 duration' I was over thinking the problem. Thanks for the help and advice
Old Jan 13, 2008 | 02:05 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
In lieu of an official industry standard, 0.050" numbers give one a fairly straightforward indication, but not the full picture. So, IMHO it's more like an apples to pears comparison.
To get a better idea of a cam's profile, in addition to looking at 0.050" numbers it's a good idea to see what the 0.200" specs are. And, the advertised specs are still important, tho harder to quantify with there being no industry standard, since valve opening and closing events are specified at that point and the lash ramps can vary how the profile begins its approach to 0.050", also.
Of course, for those who want more detail you could check the specs of Cam Dr or Cam Pro Plus files on the cam(s) in question. Then there's Perf Trends' Cam Analyzer w/test stand setup if you reeealy want to see what you've got in your hands.
For most of us, the 0.050" numbers will suffice
To Cams; Advertised duration vs. .050 duration
