bad bad news
Old Jan 12, 2008 | 05:43 PM
Sully1882's Avatar
Sully1882
Default bad bad news
went with 2.5" wheel adapters all the way around and in the front they are fine. In the back I am hitting the parking brake bracket. I have stock C5 thinspokes 2000-2004 with kumho 275/40 R18 in the back and the wheels won't clear. The tires aren't touching... it's the lip of the rim that is touching the parking brake bracket. I know some of you other guys have used the 2.5" adapters ... so how did you deal with this problem???? any help would be great!
Sully
Old Jan 12, 2008 | 05:48 PM
Red 69's Avatar
Red 69
This is a simple fix. I haven't needed to do it as I went with offset T/A's, but do the following: Put your stock wheels back on and drive to a welding shop, I assume you do not weld. Cut the E-brake bracket off with a cutoff wheel and move it to the top of the T/A, and weld it on. You want to grind the welds to remove the bracket, so it can be re-used on top of the T/A. Problem solved.
Old Jan 12, 2008 | 05:50 PM
lakebumm's Avatar
lakebumm
2022 C2 of the Year Finalist - Modified
MOVE THE PARKING BRAKE BRACKET TO THE TOP OF THE CONTROL ARM.
Old Jan 12, 2008 | 06:47 PM
TEXASDESERTVETTE's Avatar
TEXASDESERTVETTE
If You Do Use An Electric Welder...Be Sure To Disconnect The Push On Wires From Your Alternator..During The Arc Welding Process.....
Old Jan 12, 2008 | 10:38 PM
Sully1882's Avatar
Sully1882
well crap... now I'm just jumping around cursing.... I guess I'll cut'em and then drive up to where I can get them welded on.... not like the parking brake works too well on these cars anyways... oh well! Thanks for the help guys...
Sully
Old Jan 13, 2008 | 12:54 PM
Sully1882's Avatar
Sully1882
does anyone have any pics of these parking brake brackets relocated? I'm getting ready to grind off the welds and would just like to see how others have been relocated. Still bummed about this, I was so wanting to get the new wheels and tires on this weekend.
Sully
Old Jan 13, 2008 | 01:17 PM
Alan 71's Avatar
Alan 71
Sully,
I didn't know what to expect. To me 'BAD BAD NEWS' only involves the words TELEPHONE POLE or GASOLENE AND FIRE.
Hope you get your bracket moved without too much hassle.
Regards,
Alan
Old Jan 13, 2008 | 01:45 PM
BKbroiler's Avatar
BKbroiler
Sully
Here is a pic of mine. You also will have to shorten (cut and splice) the cable because the new route is shorter.
Old Jan 13, 2008 | 04:22 PM
BB72's Avatar
BB72
Default relocated bracket
Here's a good pic...
Old Jan 13, 2008 | 05:00 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
mine fit with just a mild trimming of the bracket.
To bad bad news
