Where are/should be the Head Casting Numbers
Old Jan 12, 2008 | 08:08 PM
tomard's Avatar
tomard
Default Where are/should be the Head Casting Numbers
Where would I find the head casting numbers on heads that I not too long ago removed for some new AFR's???
The only numbers that I see are on surface under valve cover between some of the stud/valve springs/rockers.
They are:
GM 16
079261
F125
21
Would the casting number be on outside or am I looking in right spot?
Old Jan 12, 2008 | 08:31 PM
dannyman's Avatar
dannyman
14079261 - '86 350
so says Mortec site.
Old Jan 12, 2008 | 09:49 PM
tomard's Avatar
tomard
Is that bad for some reason?
To Where are/should be the Head Casting Numbers
