compression ratio Ques
Old Jan 13, 2008 | 03:12 PM
ajstr1265's Avatar
ajstr1265
Default compression ratio Ques
I rebuilt my 76 L48. Replaced the bearings, rings etc. I left the bottom end alone and kept the stock pistons, rods and all hard parts. I installed a set of 202 heads with a 64cc chamber. How much did this raise my compression ratio. The stock heads are 76cc and I think the original ratio is 8.5 to 1.
Old Jan 13, 2008 | 03:22 PM
jackson's Avatar
jackson
two questions:
  • What head gasket came off it? what'd it look like? thin shim steel or thick composition?
  • Same gasket question for what you put back on w/ 64cc heads? And do you know p/n of new gasket?
Old Jan 13, 2008 | 03:51 PM
dannyman's Avatar
dannyman
Here you go. Try this calculator:
http://www.21cgt.com/FMWebCatalog/frmConversion4.aspx
Old Jan 13, 2008 | 06:33 PM
ajstr1265's Avatar
ajstr1265
Originally Posted by jackson
two questions:
The only thing I can tell you is that it was the stock gasket that came off and probably the same that went back in. I got the gaskets in a Fel Pro set from the auto parts store.
Old Jan 13, 2008 | 10:03 PM
dgruenke's Avatar
dgruenke
The one from the Fel-pro set is probably a .041 gasket, which will lower your compression from the stock gasket.
Old Jan 13, 2008 | 10:08 PM
jackson's Avatar
jackson
In all reality, OE dished piston L48 was much closer to 7.9:1 scr ... your 64cc heads & gasket KIT head gasket probably pushed it very close to just under 9:1.
Old Jan 14, 2008 | 01:22 AM
RIJVETTES's Avatar
RIJVETTES
No more than 9.3 cr- relying on factory specs and the info you provided.
Old Jan 14, 2008 | 10:02 AM
ajstr1265's Avatar
ajstr1265
Thanks for the replies. I am not a mechanic, but I was able to build this with the help of a friend who is. I wish I could have given you more specs. The bottom end is bone stock. I can say the car does run its a** off and is very reliable. I was not looking for a rocket but wanted to be able to run when I needed it.
before
after
Old Jan 14, 2008 | 10:40 AM
rponfick's Avatar
rponfick
Great work. You put a few hours and that cleanup and rebuild.
What is the thickness of you air filter element. It looks very thin, but that could just be the picture angle. It appears the stud holding on the filter lid protrudes above the filter and might allow for a thicker filter. I'm sure you have closed the hood by now and everything clears.
Ralph.
Old Jan 14, 2008 | 11:01 AM
ajstr1265's Avatar
ajstr1265
Ralph.
I think it is about 2". The regular air cleaner hit the hood in the rear. I have a Edelbrock RPM Performer manifold which raised everything. I still need to deal with the stub issue. Just something I have not gotten to do yet. (along with a thousand other things)
Old Jan 14, 2008 | 11:07 AM
rponfick's Avatar
rponfick
If it helps any, the NAPA 6037 filter is 2 1/2". I faced the same issue and was looking for something less than the stock 3" filter.
Ralph.
Old Jan 14, 2008 | 12:00 PM
ajstr1265's Avatar
ajstr1265
Thanks, I will try that!
Jim
To compression ratio Ques
