Damage to Rear Leaf Spring from PowderCoating ??
Old Jan 13, 2008 | 11:30 PM
Z069's Avatar
Z069
Default Damage to Rear Leaf Spring from PowderCoating ??
When I first had this chassis together (before the decision to coat the frame)....we had the suspension only coated...including the rear leaf spring assembly.
Upon reassembly, I had a HELL OF A TIME getting the spring into place.
Once together the rear of the car looked like it had an 6" lift.....
You couldn't even push the car due to the fact that the half-shafts were binding.
I know this is not right, because when we dragged the car out of the original owners garage, the whole car was nice and low.
Anyway, I took some pics of the rear spring and some measurements...
The coater told me he's never had a problem coating leafs.
Is it possible the heat re-arc'd the springs ?? It's only 400 degrees (??)
Here are the pics and dimensions...mabey someone can give me a comparison....
Old Jan 14, 2008 | 12:39 AM
Matt O's Avatar
Matt O
At what temperature does he "bake" the items after he powder coats them?
Old Jan 14, 2008 | 07:43 AM
bashcraft's Avatar
bashcraft
My guess would be that the additional friction between the leaves caused by the powder coating isn't letting them slide against each other. Do you have the plastic thingys (can't remember what they're called right now) installed between the leaves? I can't see them in the pictures.
Old Jan 14, 2008 | 08:18 AM
fugawi's Avatar
fugawi
have you moved the car around to let everything settle back down? if you don't then it looks like a lifted truck....driving it would be the best to settle it....
Old Jan 14, 2008 | 08:23 AM
Z069's Avatar
Z069
400 degreess....I noted that above
Yes you can see them in the pics..the leafs are silver and the plastic liners are in black.....actually, the coating should made them even slippery (??)
I know what you mean.....you would just have to move it a few feet.
I'm telling you, this rear spring has major tention now.
I guess we need to purchase a new spring.
What types of aftermarket leaf-packs are available ??
John
Old Jan 14, 2008 | 10:09 AM
Jim_Harrison's Avatar
Jim_Harrison
Comming from a heat treating backround, I doubt 400 F made any difference. If the temperature was too high it would make the spring softer or temper it and that would have a tendency to take the arch out or relax the spring. Take a picture of the assembled rear and post it on this blog to see if we can find any assembly errors.
Old Jan 14, 2008 | 12:07 PM
71rdster's Avatar
71rdster
It will settle when the body and drive train are reunited with the frame and it gets driven a bit.
Old Jan 14, 2008 | 03:13 PM
7T1vette's Avatar
7T1vette
400F would certainly cause some tempering "activity" with the spring. Apparently [from the photo] it caused the spring to release some internal stresses and bowed the heck out of it. I'm a little surprised that happened, but do you really know that the temp only went to 400F? (I suspect it was higher than that.)
Old Jan 14, 2008 | 03:28 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Is the body on the frame now?
Old Jan 14, 2008 | 06:18 PM
stpman's Avatar
stpman
I had my spring powder coated and I just measured it and where you are showing 11" mine is only 7 1/4"
Steve
Old Jan 14, 2008 | 06:37 PM
JBristow's Avatar
JBristow
I had egxactly the same problem after I installed the leaf spring, I didn't have the half-shaft binding problem. I drove less than one block when the spring settled in to it's normal location.
Old Jan 14, 2008 | 06:44 PM
tlynam's Avatar
tlynam
I have a somewhat new replacement spring out of my car now. It measured 9 3/4". Ride height was OK when in the car.
Old Jan 14, 2008 | 08:55 PM
78Vette-SA's Avatar
78Vette-SA
Looks familiar. This was my 63 spring after re-arching. Definately have to roll it around a bit. I can't imagine 400 degrees would cause it to bend that much but then again metalurgy is not my thing.
Old Jan 14, 2008 | 09:18 PM
coinwasher's Avatar
coinwasher
I had the same issue after I had my springs powdercoated. The car sat way up until I drove it a bit. I did end up having to go with longer spring bolts so that I could pull the a$$ down. I always suspected that the actual powdercoating held the springs in a more arched position (remember each leaf is apart for powdercoating) coupled with the thickness of the new liners. At theend of the day I got the back end down and the ride is supurb.
Old Jan 14, 2008 | 10:26 PM
Jim_Harrison
There is a lesson to be learned here. Do not let any of your high strength steel parts, i.e. springs, axles, gears, rods, cranks etc. ever see over 200 F. And never let any aluminum parts get over 200F. Unless you know exactly what the material is and what temperatures it was tempered at or what that particular alloy was designed to handle. And while were at it don't have your high strength steel parts cyrogenicaly treated without being properly tempered afterwards. Not sure, go find a degreed Metalurgist.
Old Jan 15, 2008 | 04:11 AM
7T1vette's Avatar
7T1vette
An interesting side-note:
Cryo-hardening is really just a metallugic oddity which is being marketed for big buck$. Just because the surface hardness of a metal gets 1 to 2 points harder after being placed in a really nasty environment isn't a good reason to throw money at something. Anyone ever consider "What else happens to the metal when it's subjected to extremely low temperatures?" Well, for one thing, there can be a spontaneous separation of the boundary layer between "surface hardened" and "core material"....while it is in use... or when it is just sitting on a shelf NOT being used. Yep...it can happen. Lesson learned: Don't throw money at WEIRD sounding stuff! It may have some basis in fact, but rarely is it beneficial.
Old Jan 15, 2008 | 04:35 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
From my own experience with powder coating, I can't imagine the coated parts having more friction than uncoated. The powder tends to be pretty slick unless it's a textured formula.
I'm pretty sure rods, cranks, etc. are going to be seeing temps in excess of 200*F...
Old Jan 15, 2008 | 11:15 AM
Jim_Harrison
I'm pretty sure rods, cranks, etc. are going to be seeing temps in excess of 200*F... [/QUOTE]
Rods and cranks will reach whatever the temperature of the oil gets, 250F? The high quality ones are made from 4340 steel but not hardened very high, with the cranks being nitrided. They probably can go well over 300 F....still don't do it unless you know what the prior processing history of the part was. Some steels, like carburized gears are tempered at 250F, anything over that will soften them.
Old Jan 15, 2008 | 07:10 PM
FB007's Avatar
FB007
To Damage to Rear Leaf Spring from PowderCoating ??
