TH400/Holley Compatability Question
Old Jan 15, 2008 | 06:14 PM
Toyvet's Avatar
Toyvet
Default TH400/Holley Compatability Question
Just purchased a Holley Model 4160 Carburetor and plan on using on a 1969 350 cu engine mated to stock TH400 transmission.
The instructions say that this carb cannot be used with an OVERDRIVE type trans, so the question is, is a TH400 an overdrive type trans ?
Any help would be greatly appreciated.
Old Jan 15, 2008 | 06:19 PM
Scott Marzahl's Avatar
Scott Marzahl
A TH400 does not have overdrive, it's just a 3 speed. Something like a 700R4 would be an example of an overdrive trans.
What was wrong with the stock Q-jet?
Old Jan 15, 2008 | 06:24 PM
7T1vette's Avatar
7T1vette
The "gas" is greener on the other side....
Toyvet's Avatar
Toyvet
Default Thanks Scott
Thanks for the help...
This is a non original engine that was installed while the original 427/400 awaits rebuild. Thank you again
To TH400/Holley Compatability Question
