carb fuel line setup
Jan 15, 2008 | 09:38 PM
St. Jude Donor '08
Anyone have pics of their fuel lines from the mech pump to the carb? I am getting rid of the glass filter and braided lines to get rid of the fire hazard and give it a cleaner look. Holley 4bbl. I dont know much about the AN fittings but I can bend the hell out of tubing so I will probably just use 3/8 tubing. Also which filter you are using. just looking for some ideas. fuel pressure guages, all of it. thanks in advance
78 w/350
Jan 15, 2008 | 09:46 PM
an fittings are expensive as hell, but they do look nice. an-6 I believe is for 3/8ths line. I put the line for my fuel pump to carb and it was over a hundred bucks easily.
Jan 15, 2008 | 10:10 PM
Is this for dual feed Holley, if so, I would pattern your lines after an LT-1 setup.
Jan 15, 2008 | 10:39 PM
Holley fuel pump & regulater, Earls filter
Jan 15, 2008 | 10:46 PM
Jan 15, 2008 | 11:37 PM
[IMG]
[/IMG]
Jan 15, 2008 | 11:50 PM
Very simple with a 3/8 tubing bender from the 850 to the stock pump and a 3 way compression union.
Back together after 35 years
Jan 16, 2008 | 07:57 AM
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
stock 68 327 set up, I know its a Qjet, but you get the idea....
the dogleg bend is to clear the air cleaner
tim
Jan 16, 2008 | 11:21 AM
I have a complete paper on how to build fuel lines, along with part numbers and photos. Driop me an e-mail for the paper:
V8FastCars@msn.com
Lars
Jan 16, 2008 | 07:57 PM
St. Jude Donor '08
email sent! thanks to all for the photos!!
Jan 17, 2008 | 06:48 AM
[IMG]
[/IMG]
