Power Steering Valve
Old Jan 16, 2008 | 11:21 AM
billsfan's Avatar
billsfan
Default Power Steering Valve
I just got my control valve rebuild kit. For some reason, the kit does not include the 1 gasket that the valve uses. I can't find one anywhere. Should I use RTV sealer where the gasket should be? The valve came apart easy, and seems straight-forward to put back together. Any other tips?
Old Jan 16, 2008 | 01:18 PM
wnmech's Avatar
wnmech
Billsfan It has been awhile since I overhauled mine which gasket are you refering to? Do you mean the rubber boot that goes over the rod that sticks out?
Old Jan 16, 2008 | 04:15 PM
79VAVette's Avatar
79VAVette
http://jimshea.corvettefaq.com/
Jim Shea's papers are a MUST read when doing any steering related rebuilds. He has tips and details that the service manual, etc. don't.
Old Jan 16, 2008 | 06:31 PM
billsfan's Avatar
billsfan
I figured it out. It's called a gasket, but it's metal. It fits over the annulus spacer between the two main sections. Bubba had rebuilt it, and there was red RTV everywhere. I rebuilt it without any gasket cement. If it still leaks, time for a new one!
Old Jan 16, 2008 | 06:32 PM
billsfan's Avatar
billsfan
Thanks for the info!
Old Jan 17, 2008 | 05:09 PM
wnmech's Avatar
wnmech
I can't help you out with that part. I had the seal that goes over the ball stud if you needed it.
Old Jan 27, 2008 | 10:49 AM
Joe45's Avatar
Joe45
Got one of those new steel gaskets with my seal kit from Zips.
Old Jan 27, 2008 | 11:13 AM
Hitch's Avatar
Hitch
Here's a little thread I wrote when I did mine not to long ago that helps fill some gaps in the papers found out there on the web..
Dave
http://forums.corvetteforum.com/show...ighlight=power
Old Jan 27, 2008 | 11:26 AM
Joe45's Avatar
Joe45
Rebuilding my 81 valve now. Is it me or does the rebuild instructions and my 81 manual miss showing the large washer installed before the annulus seal is installed? If I have it right, annulus spacer, then large washer, then seal (lip up), then spring retainer then spring etc.
Correct?
Old Jan 27, 2008 | 11:38 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
When you get your valve rebuilt, don't over grease it. A few shots is sufficient. A rebuilder of these told me a long time ago that that is why most leaks start as to much grease will move seals around. He also said to have the engine running when greasing it.
To Power Steering Valve
