One of the twin wires connecting to the battery terminal on the starter wires was really brittle and snapped when I went to reattach it to the solenoid just above the fusible link. Now I need to replace the wire and the fusible link. I figure I should change both wires and links, since the other wire is likely just a brittle or close.
I've got the wiring diagram and one is 20 to 16 and the other is 14 to 10.
Where do I get a fusible link? This happened tonight so all I've been able to do is search the net and none of the major vendors sell replacements. I want to do this tomorrow night or Saturday morning so shipping something is not really an option. Is there someplace local that would carry this?
If I understand this correctly this is just a standard solder in situation once I find the links.
Can anyone help or point me in the right direction for purchase and replacement?
Back when I was working in dealerships we had fusible link on rolls just like wire so we could make them up. You might try a NAPA parts store as they pretty much have or can get anything automotive. Hopefully you wont have to buy a 25 or 50 foot roll of it.
The "fusible link" IS the smaller wire in series with the larger wire. All that did was provide a "last resort" site for an overload to melt a wire in an selected location in the harness. When a wire goes from, say, a 10 awg to a 14 awg and then back to 10awg, the 14 awg wire is the fusible link. It was cheaper to provide a selected location for a wire melt-down (where the risk of occurence was low) than to install a circuit breaker or other costly hardware. GM did this very effectively for may years, and not too many of these "links" failed before 25-30 years went by or there was a major malfunction in an alternator, etc or a dead-short in a harness. You can replace damaged fusible links by using the same strategy. However, I would not suggest putting your own fusible links wherever you want one; limit your use of them to duplicating the original design.
I've purchased rolls of fusible link wire at AutoZone as recently as a couple years ago. It's not just wire per se, it actually has softer insulation that blisters and swells when it overheats. You can easily create a new fusible link by cutting out the damaged section of the old one and splicing or soldering in a new piece.
Don't mean to hijack this thread, but what would be wrong with installing a resettable circuit breaker in that circuit ?
nothing technically; make sure the connections are rated for the current and make them good. a few don't like additional connections due to added resistance. some say, fuse link not a problem why fix it . . .
carquest and others sell by ft as well as pre-packaged
advance, autozone, etc has pre-packaged
from memory: make about 6 in long
Friday night I made all the connections and got everything back in place.
The part that was messing me up was a plastic like material that has enclosing the connection. After checking out the connectors at the local autozone I think they may have been some sort of solderless connection or intentional identification mechanism.
fusible links in various sizes. That's where I've bought mine. Solder it in, heat shrink the solder joint, and you're good to go.
I'd do a continuity check prior to sealing with the heat shrink.
some factory links had a large "fat" spot in the wire. i'm told this is insulation. not sure if that is what you saw. glad it's fixed now
