Lug Studs
Old Jan 18, 2008 | 12:21 PM
stinger12's Avatar
stinger12
Default Lug Studs
Will I have to change my lug studs if I decide to upgrade to torque-thrust aftermarket rims...my lug studs are the same size as the original ones.
Old Jan 18, 2008 | 12:34 PM
Gordonm's Avatar
Gordonm
No I have the stock studs on my TTIIs.
Old Jan 18, 2008 | 12:36 PM
stinger12's Avatar
stinger12
what size tires are you running? I want to put wide tires in the rear. I just bought offset trailing arms...I was also thinking about putting flares on the back end. So any size torque thrust 2's will work with the stock studs?
Old Jan 18, 2008 | 01:05 PM
Gordonm's Avatar
Gordonm
I am running 18X10 rear rims with 275 40 18s and the front is a 17X8 with 255 45 17 tires. I am running stock trailing arms with this setup also. No flares either.
Old Jan 18, 2008 | 01:07 PM
1fastC3's Avatar
1fastC3
im pretty sure if you go with too wide of a tire the e-brake bracket comes into play as a problem(unless you can weld or the new t/a's have provisions for either), also you dont want the wheel and tire to rub up front. more forum member that can better answer the question will chime in soon.
ps i love the TT2's good choice
-alex
Old Jan 18, 2008 | 01:12 PM
stinger12's Avatar
stinger12
The offset arms already have the parking brake bracket repositioned on top of the arm. They also allow for wider tires without having to use flares. I like the look of flares though, that's why I was thinking of using them and installing really wide tires. My car is custom anyways...I could care less what others think about it.
Old Jan 18, 2008 | 01:29 PM
Gordonm's Avatar
Gordonm
You could then most likely fit in a 12 inch wide wheel and run something like a 325 rear tire with flares.
Old Jan 18, 2008 | 01:32 PM
lvrpool32's Avatar
lvrpool32
18 x 13 with 345's with flares
Old Jan 18, 2008 | 01:35 PM
stinger12's Avatar
stinger12
Ahhh, that's what I'm talking about. That would look Now I've got to figure out where to buy the rims from. I'm looking for the cheapest place. I'll probably be buying them in about two months, but I am just trying to plan for the future.
Old Jan 18, 2008 | 01:37 PM
stinger12's Avatar
stinger12
That's even better! Those should scare the vehicles behind me when I am in traffic
To Lug Studs
