Do I need a bracket for the a/c when I remove the A.I.R. pump on a 1980 if I do does anyone Know where I can get one or what that part # is so I can order it? Thanks.
Doesn't the AIR bracket mount in front of the AC bracket? Shorter bolt may be all you need. At least on a 79.
You will need shorter bolts at the water pump were the bracket was removed. Remove the pump pully and done if I recall. I will look at mine to make sure.
I looke today and a I stated above that is all you need to do. I also replaced my water neck to clean things up.
Hope that helps
