balancer won't budge
Old Jan 18, 2008 | 05:37 PM
thunderlips's Avatar
thunderlips
Default balancer won't budge
I have removed the 1 bolt, washer, and 1 big washer and then put the balancer puller to work. I am turning the whole crank so i put a rubber mallet to keep puller and crank from rotating and turned it very hard and the thing still won't come off. Am i doing somthing wrong?
Old Jan 18, 2008 | 05:42 PM
SIXFOOTER's Avatar
SIXFOOTER
So you have the crows foot puller with 3 bolts installed and when you turn the center bolt the whole thing turns?
Use a long prybar between 2 of the mount bolts and the cebter bolt to hold it and then go at it.
Old Jan 18, 2008 | 06:17 PM
Durango_Boy's Avatar
Durango_Boy
Make sure you coat the threads heavily with oil of some kind to help lube it and to cool it. I have de-threaded more than a few of the light duty pullers on stuck balancers.
Old Jan 18, 2008 | 09:04 PM
thunderlips
hey thanks for the advice, the bastard finally came off!
Old Jan 18, 2008 | 10:08 PM
Durango_Boy
Good job.
Old Jan 19, 2008 | 03:11 PM
Disco_Mike's Avatar
Disco_Mike
Good tips. I need to replace mine also.
To balancer won't budge
