Transistor Ignition System
Old Jan 19, 2008 | 01:09 PM
pwsusi's Avatar
pwsusi
Default Transistor Ignition System
Can someone with an LT-1 please post a picture of the transistor ignition? Or, if you have an LT-1 that is missing the TI, can you post a picture of the holes where it was supposed to be mounted.
Thanks,
Paul
Old Jan 19, 2008 | 01:22 PM
dmayhew's Avatar
dmayhew
You could never get a camera to take a decent photo where the box mounts. too tight a spot to see holes. If box is there then a photo would show that.
open the hood and stand in front center of car.
look to the front side of the inner fender just opposite of where the front wheel is.
There will be 3 holes 1 at top and 2 down.
David
Old Jan 19, 2008 | 02:09 PM
pwsusi's Avatar
pwsusi
Thanks David. I was having a tough time seeing...I'll check again later. I think I read in another thread that you can also see the holes in front of the front driver's side wheel (not by looking under the hood, but by looking in the wheel well in front of the wheel). I do see 3 holes there, I will take some pictures.
Old Jan 19, 2008 | 04:35 PM
early shark's Avatar
early shark
There is a difference when viewing those triangular shaped 3 holes in the inner well between a LT-1 and a big block with TI.
Old Jan 19, 2008 | 05:34 PM
mstanton's Avatar
mstanton
Not the best picture, but you can see the TI amplifier.
Old Jan 19, 2008 | 05:39 PM
pwsusi's Avatar
pwsusi
Took this picture of the wheelwell in front of the driver's side front tire. Are these the three holes?
Old Jan 19, 2008 | 05:41 PM
pwsusi's Avatar
pwsusi
Thanks mstanton for the picture.
Old Jan 20, 2008 | 08:34 AM
pwsusi's Avatar
pwsusi
Any comments on the picture I posted?
Thanks,
Paul
Old Jan 20, 2008 | 09:29 AM
mstanton's Avatar
mstanton
Thanks,
Paul
Paul,
That looks like the bolt holes for the TI amp to me. That's very similar to my 70 which still has the amp installed. The rest of the TI system is on a shelf waiting to be rebuilt and reinstalled.
Mark
Old Jan 20, 2008 | 09:32 AM
mstanton's Avatar
mstanton
What is the difference? Wasn't the LS6 the only 70-72 corvettes with TI, other than the LT-1?
To Transistor Ignition System
