Hard Start Up1
Old Jan 19, 2008 | 04:50 PM
siko123's Avatar
siko123
Default Hard Start Up1
My 69 Vette's 350 engine was just totaly rebuilt. Before starting I pump the gas 3 or 4 times. When I start the car every day the car starts fine. When I don't start it for 1 week I have to crank it for about 30 seconds before it starts. After starting it revs at 1200 for about 45 seconds and as soon as I pump the gas the idle drops to 800 revs. Is there something wrong or is this normal. Thanks as usual for the help.
Old Jan 19, 2008 | 05:29 PM
nutsy's Avatar
nutsy
my 454 was not rebuilt but it starts same way. i beleive when you hit gas when idleing high you knock choke off which makes rpms drop. i think after not running for a while gas has to be pumped to carb which takes a while.
Old Jan 21, 2008 | 05:11 PM
siko123's Avatar
siko123
Default 69 Hard Start Up
Thanks I guess it's just something I have to live with. Thanks again.
Old Jan 22, 2008 | 04:50 AM
7T1vette's Avatar
7T1vette
Sounds like the carb fuel bowl is leaking out when sitting. 3-4 pumps on the carb, just to get it to fire, sounds like a lot. Maybe the accelerator pump seal is worn out. (Was the carb recently rebuilt, too?)
Old Jan 22, 2008 | 05:48 PM
siko123's Avatar
siko123
Yes the carb was rebuilt along with the engine. Thanks
To Hard Start Up1
