installing a 68 gear box
Old Jan 20, 2008 | 06:08 PM
Dan Michael's Avatar
Dan Michael
Default installing a 68 gear box
Hello everyone I finishing the car before it goes to the body shop and had the steering box rebuild and the pitman arm is hard going on is this normal ! Thank you Dan
Old Jan 20, 2008 | 06:41 PM
GTR1999's Avatar
GTR1999
No, it should fit the splines without effort. There are wider splines every 90* inside the pitman arm but sure you have the box centered and the arm will fit & point forward. Were the gears replaced or are they original? Some of the new gears may have a very slight narrow fit compared to originals but you should be able to install it. The nut has to be torqued to 140+ ft/lbs. I set them at 150ft/lbs.
If this is newly rebuild does it have a snug feel on center?
