Speedo cable??
Old Jan 20, 2008 | 06:26 PM
Brown78's Avatar
Brown78
Default Speedo cable??
I need to change my cable. what is the best way to do this???
Old Jan 20, 2008 | 08:32 PM
r44s's Avatar
r44s
you can only get it out from the speedo. Tilt the speedo/dash out and remove the cable from behind the speedo. . New cable must be installed same way
Old Jan 20, 2008 | 09:12 PM
Brown78's Avatar
Brown78
Thanks for the heads up.
Old Jan 20, 2008 | 11:48 PM
blk79nj's Avatar
blk79nj
I was able to get it out of my '79 without removing the dash. If you kneel outside the car, reach under the dash with your right arm. Follow the cable to dash. There is a little tab that when pushed, it will release it from the speedo. The new cable will 'snap' back on.
If you have criuse, your car will have 2 cables.
Old Jan 21, 2008 | 01:37 AM
r44s's Avatar
r44s
This will work as well with patience.
To Speedo cable??
