Fuel Injection question
Can I use this with my motor?
What computer do I use? Painless?
I know fuel pump and regulator need to be done
Just making sure it will work before puchasing.
If it were me, I would use one of the latest after market ECU systems like Accel, Fast XFI or Big Stuff. more $$, but worth it IMHO.
You can go with a GM ECU if you want to really dig into the technology using MEFI Scan & Tune, or EFI live for later model GM stuff.
Bullshark
P.S Here it is I found it
http://www.sallee-chevrolet.com/Disc...3418/3896.html
Bullshark
I'm not concerned with hood clearance. If it doesn't fit, we go L88
Do I have have to run new fuel line I know the current line is 3/8 and the return from the carbon canister is 3/8
Bullshark
Bullshark
Carbon canister line is steel just like fuel from tank. The vapor line does dump into the top of the tank.
Any pics of your work?
Too small a return line can cause pressure fluctuations to the injectors. Also, IMHO, you don't get an optimal (and sometimes even satisfactory) tune when you have some remote tuner burn you a canned calibration. Not only that, you are held captive for any future mods. That is why for myself, I insist on having control of my destiny.
Accel, Fast, Big Stuff among others give you that flexibility. It is becoming a wide open market now that MSD, Edelbrock among others have also jumped in and now offer very capable systems.Let me know when you home in on your preferred configuration or need any opinions, I will glady offer my 2 cents
Bullshark
P.S. I forgot to mention that the return nipple on the fuel tank needs to be replaced to accommodate a larger return line. It will do no good to run larger (3/8) line only to pinch down to 1/4" at the nipple.
What I have found to me more important is where the pickup is located. With any less than a half tank of fuel, my pump will starve during hard acceleration. It's a PITA, because you effectively cut the tank capacity in half. I plan to put a sump in soon to solve this problem. When I do, I will add a bigger return fitting so my rubber hose fits better.
Ken
Again, 5/16 is probably going to be ok for smaller engines, but those BB gas guzzlers are a different animal. Again, if you have to run a new line may as well use 3/8". Internal fuel pumps that can handle the demand have their advantages.
My applications were with older 69-72 vintage vettes.Bullshark
Ken
Bullshark
oh. Buy the way Ken, I still have your stim board, turns out Gene's megasquirt does have some kind of I/O problem I haven't got around to troubleshooting yet. Let me know if you need it back soon.
Bullshark
I had a strange feeling there was something wrong with the MS. The problems didn't make sense. I don't need the stim right now, so go ahead and hold onto it.
Ken
My experience with the Megasquirt is that lots of people can get their engine to run. The devil is in the details. Some of the things that seem easy are not. A key example is light load cruising. My engine does not like my current combination of spark and fuel and the result is some surging. The key to tuning anything is knowing what the engine is doing. If you don't have a wideband, or if you don't know what lean backfiring sounds/feels like; etc, you can't tune. I have learned so much more tuning my engine than if I bought someone else's computer. It has been fun, and I wouldn't do it any other way. Not everyone thinks it's fun though, to be sitting on the side of the road making changes on a laptop.
Ken
