Flex exhaust pipe
Old Feb 25, 2008 | 09:41 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Im not using it. I ordered 8ft straight pipe and a universal x pipe along with a u bend all in 2.5 inches. Im going to modify my crossmember and build my own system. Orded it form jegs for 141 shipped to my door.
Old Feb 25, 2008 | 11:24 PM
Ironcross's Avatar
Ironcross
Most auto supplies offer this stuff as it`s cheap and flexible when new. It comes in all sizes and the size is by inside diameter {ID} to go over the connecting pipe.and comes in 10 ' lengths. The larger sizes are for trucks. Nothing offensive either but we comically called it 'Jewish exhaust' because of the price and is sold by the foot.
Old Feb 26, 2008 | 08:45 AM
vettfixr's Avatar
vettfixr
There are better solutions to flex pipe than the corrugated stuff. Here's an example from Summit
http://store.summitracing.com/partde...5&autoview=sku
Here's another example
Old Feb 26, 2008 | 10:59 AM
Ironcross's Avatar
Ironcross
Those are flexible joints commonly found on 4 cylinder exhaust systems and some trucks. The shaking of the small engines would cause failures in there exhaust systems with out this joint. This is a clever use of them in a performance exhaust that acts the same way because of modifications .
Old Feb 26, 2008 | 11:17 AM
kevinator80's Avatar
kevinator80
About a year ago I ordered two of the flex pieces without the flange. After being on back order for a month I canceled the order. I see that Summit says it is available today but the one with the flange wont be available until 3/6. I still need two of them myself so check with summit before you order because there may be a faster source if they are back ordered.
Old Feb 26, 2008 | 11:43 AM
Ironcross's Avatar
Ironcross
Muffler shops have access to all of those exhaust parts and can weld flanges on any size pipe wheter flexoble or not. Go to a shop that does custom bending and they shouild be able to set you up.. I know my exhaust system warehouse has all the necessary parts so i`m sure one in your area would probably have them also.
Old Feb 26, 2008 | 12:50 PM
rajsid's Avatar
rajsid
Have anyone used these for longer period of time(a few years)?
Do they leak or crack like the flex pipes?
Sounds like a good solution to exhaust damage due to engine shaking besides they are really popular in the Japaneese car market.
Old Feb 26, 2008 | 01:29 PM
vettfixr's Avatar
vettfixr
If I'm not mistaken they came standard on a few cars I've owned (350Z,TSX)
