Temp Sensors for Vortec Heads
Old Jan 24, 2008 | 07:14 AM
maggie82's Avatar
maggie82
Default Temp Sensors for Vortec Heads
I have a question about the temp sensors in the heads. Im finishing up a Vortec swap on my 1971 L48. The old sensors are much bigger in thread size than the sensor holes in the late model heads. Im curious what people are doing to get their sensors hooked up?
Old Jan 24, 2008 | 07:27 AM
BKbroiler's Avatar
BKbroiler
I put the stock temp. sender in the intake manifold, near the thermostat housing.
Old Jan 24, 2008 | 09:13 AM
Durango_Boy's Avatar
Durango_Boy
I wonder if it would be bad for the head to drill and tap the smaller hole to fit the stock sensor.
Old Jan 24, 2008 | 10:10 AM
maggie82's Avatar
maggie82
I believe there is a sensor in each head, does it matter which one I use?
Old Jan 24, 2008 | 10:26 AM
Durango_Boy
The stock sender for the temp gauge is in the driver's side head. The passenger side head wad the TCS switch, but I don't know that have or would need to have it. Most stock TCS switched get removed anyway.
Old Jan 24, 2008 | 10:36 AM
vettfixr's Avatar
vettfixr
I installed World Products SR Torquer heads on my L48 a few years back and ran into the same problem. I ended up drilling the heads with a hand drill and tapping them with the correct size thread for the original sensor. I have to say it was a pucker 10 and I was really worried about screwing up a brand new set of heads. But as it turned out I had no problems and no leaks. If you're not sure of your skills or would just rather have it done for you I'm sure a competent machine shop could drill the heads and tap them for a reasonable price.
Also, at the time I had my original intake manifold on the engine. If I had my current manifold I probably would have installed the sensor in the intake. Drilling those heads made me very nervous.
Old Jan 24, 2008 | 10:38 AM
Durango_Boy
I think if I had to attempt that I wouldn't have any problems, but I cannot speak for the OP.
Old Jan 24, 2008 | 10:50 AM
straub18045's Avatar
straub18045
Apparently 'corvette paramedics' has a sensor, but original connector will not work. I used a gm one from I forget what year, make and model. The resistance was the same and screwed right in. Give me a couple days and might be able to give you a part #
Old Jan 24, 2008 | 06:03 PM
mvette76's Avatar
mvette76
i used a temp sensor off a 82 corvette for mine has the smaller thread and blade connector and reads right with my stock 75 gauge i think i bought it at autozone for 12 or 13 bucks.
To Temp Sensors for Vortec Heads
