another hood stuck post
Old Jan 25, 2008 | 04:39 PM
Gumby86's Avatar
Gumby86
Default another hood stuck post
I closed my hood on my 81 vette and now it wont open. I do not know what to do. I searched the archives and havent really found much. I tried to stick a wire hanger inbetween the hood and firewall with no luck. I cant wiggle it free. Does anyone know another tip? Would I be able to reach the bolts in the front and take it off that way? Thanks.
Old Jan 25, 2008 | 05:15 PM
jdp6000's Avatar
jdp6000
Here is the link you may be looking for.
http://www.madvet.com/shop?frame=1.264.3852
Old Jan 25, 2008 | 05:19 PM
dobroman2001's Avatar
dobroman2001
Here's some pictures that I have that may help:
http://s189.photobucket.com/albums/z...%20if%20stuck/
Old Jan 25, 2008 | 05:37 PM
Durango_Boy's Avatar
Durango_Boy
His is an '81, and the hood latches are totally different. Even the mounting locations are a lot wider on yours than on his.
Old Jan 27, 2008 | 12:04 AM
Blain's Avatar
Blain
Just opened my '74 yesterday. Rocker panel off, filler panel (think thats what its called) charcoal cannister removed then reached up and pulled the release with my hand. Tried all the "screwdriver through the hole" tricks that you will find on other posts. No luck with that. The hard way turned out to be less time and frustration.
Blain.
Old Jan 27, 2008 | 12:31 AM
hdman1962's Avatar
hdman1962
Post on your progress, my 81 also won't open
Old Jan 27, 2008 | 01:08 AM
Durango_Boy
Blain.
The screw driver trick will only work for '77 and later hood latch style. For pre '77 systems, you have to reach them from under the car. If there is no A/C it's easy to reach up and release the passenger side. From the driver's side, as mentioned, you have to go up through the splash shield and past the vapor canister to get to the latch.
Old Jan 27, 2008 | 01:39 AM
Z-man's Avatar
Z-man
Mine's a '70, but I was able to reach the bolts in front. It's slow going, but gets the results. It also doesn't damage anything.
Old Jan 27, 2008 | 02:27 AM
Gumby86's Avatar
Gumby86
well. I tried the screw driver trick which looked like it would have worked if I knew what i was doing! :P So I am going to practice it alittle with the hood up.
I got it open though! I jacked my driver side up and was underneath it trying to reach from under my car and my buddy happened to pull on the cable one last time and it popped right open. We had just finished messing with it forever before we jacked it up and no budge. I guess from lifting the car, it shifted some weight and the hood gave way?
Old Jan 27, 2008 | 07:54 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Gumby86,
Now that it's open, hook a wire to your latches and let it hang down the firewall. (tuck it neatly away, test) Should it ever happen again you can reach under the front wheelwells and pull them to open.
Better safe than sorry.
Old Jan 27, 2008 | 10:23 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Originally Posted by Glass Act
Gumby86,
Great idea...going to do it soonest!!
Old Jan 27, 2008 | 02:08 PM
Gumby86's Avatar
Gumby86
Thanks for the advice, which I will put to good use!
Old Jan 27, 2008 | 02:15 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Gumby86,
Great idea!
To another hood stuck post
