Control Arm Help
Old Jan 25, 2008 | 05:32 PM
Sidepiper's Avatar
Sidepiper
Default Control Arm Help
Hi, I just picked up my 75 from the shop for inspection, they said the shims on the rear control are where loose and hanging out. Does anyone have a picture of the shims on the control arm installed correctly? Also is this difficult to fix myself? Thanks
Old Jan 25, 2008 | 07:45 PM
jdmick's Avatar
jdmick
Not for sure what you're referring to. Do you mean the trailing arms on the rear suspension? If so the shims are supposed to stick out a bit and they're slotted where they fit over the bolt that holds the front of the TA into the frame. There should be a cotter pin holding them in so they should be "hanging out" a bit and they don't need to be so tight that you can't move them. Has this shop had any experience with old Corvettes? If not I think I'd go somewhere else.
Old Jan 25, 2008 | 07:54 PM
A88FXRS's Avatar
A88FXRS
Shims Do Stick Out On Both Sides Of Trailing Arm. Should Have Long Cotter Pin Holding Them In. Should Not Be Loose. If They Are, Remove Cotter Pin And Tighten Castle Nut On Outside Of Thru-bolt Going Thru Frame. Replace Cotter Pin.
Ifthey Are Loose And Missing, There Is An Excellent Alignment Shop Out Here In Chester County Down 202.
Paul
1996 Lt4
1987 Convert
1974 Stroker
1969 427
Old Jan 25, 2008 | 08:14 PM
mdbelanger's Avatar
mdbelanger
Do you mean this or the other end.
Old Jan 25, 2008 | 10:18 PM
Sidepiper's Avatar
Sidepiper
Thanks for the replies, I meant the trailering arms in the rear. The shop that inspected it is just a regular shop not specializing in vettes, I will get underneath tomorrow to take a look.
Old Jan 25, 2008 | 10:21 PM
Sidepiper's Avatar
Sidepiper
Paul
1996 Lt4
1987 Convert
1974 Stroker
1969 427
Whats the name of the alignment shop, also do you know anyone exp. to rebuild my q-jet carb? thanks
Old Jan 26, 2008 | 07:37 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Lars is the man for Q-jet rebuilds, a member of the Forum.
Old Jan 26, 2008 | 11:41 AM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Sidepiper - where are you in Mont County? If you are near Soudertown, go to Jerry's on old Bethlehem Pike. I have used Jeff to the the alignment on my 3 Vettes for 10-11 years. And he is a car guy!
Jerry's Auto Body Inc.
3410 Bethlehem Pike
Souderton, PA 18964
Tel. 215 723 4068
John
Old Jan 26, 2008 | 01:50 PM
Sidepiper's Avatar
Sidepiper
Thanks John, Will I need to suppliy new shims? Thanks
As far as Lars the rebuilder does he have a website?
Old Jan 26, 2008 | 02:23 PM
Go Vette Go
Get a set of stainless steel shims - got mine from Bair's in Western PA.
Here is Lar's email address V8fastcars@msn.com
John
Old Jan 26, 2008 | 02:55 PM
Sidepiper's Avatar
Sidepiper
John
Im in Glenside, Thanks Again John
Old Jan 27, 2008 | 11:44 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Corvette rear shims are an oddball part that most shops won't have. All of the vendors carry stainless replacement kits. There are at least two different manufacturers of the kits that I've seen, but both are of comparable quality.
Old Jan 28, 2008 | 02:56 AM
AZ 7TVETTE's Avatar
AZ 7TVETTE
You definitely need a shop with lots of experience in C3's. They are different than the thousands of other cars a normal alignment shop sees. I recently had mine done correctly after installing new springs all around and it is a huge difference.
To Control Arm Help
