Stock-clutch mount for an LS engine ??
Old Jan 26, 2008 | 10:13 AM
Z069's Avatar
Z069
Default Stock-clutch mount for an LS engine ??
Where do I find a mount for the stock '69 clutch linkage ??
John
Old Jan 26, 2008 | 10:44 AM
SteveG75's Avatar
SteveG75
Assuming you mean a mount for the Z-bar ball, Scoggin-Dickey has a bracket for the clutch linkage for use with the Mark V and VI bigblocks that bolts to the bellhousing. It may work with the LS since the I believe the bellhousing bolts are in the same position on the LS. It would at least be a place to start.
Part # SDCBV
Retail Price: $59.95
The SDPC Exclusive Clutch pivot ball brackets are for use on Generation V & VI blocks. This long style pivot bracket provides proper mounting position and alignment of the Z-bar on Corvettes. The super strong brackets can handle the high pressures of racing clutches. A short style pivot ball bracket is available for use on all other GM cars and pick-ups.
http://www.sdparts.com/product/SDCBV...Corvettes.aspx
Old Jan 26, 2008 | 11:42 AM
Z069's Avatar
Z069
Right on man...thanks !!!
I'll give them a try !!!
ANYONE ELSE ??
Old Jan 26, 2008 | 11:58 AM
Cooter Tech's Avatar
Cooter Tech
I used a hydraulic clutch set up. It was a big improvement over the mechanical linkage.
Old Jan 26, 2008 | 04:03 PM
Z069's Avatar
Z069
Thats cool...but I'm concerned with mounting the stock linkage, Thanks
To Stock-clutch mount for an LS engine ??
