Holley 4110 help
Old Jan 25, 2008 | 05:35 PM
Speed Hound's Avatar
0Speed Hound
Former Vendor
Default Holley 4010 help
OK guys I need some info. I am having a hard time finding info about a Holley 4110. Took me long enough to find out what it was even. Holley's catalog doesn't even list it from what I can find. I may need to get in there and change some jets around and I needed to know if they were the standard ones or something special. Also, will the electric choke that fits on all the other Holleys work on this one?
Trey
Old Jan 25, 2008 | 06:47 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Sure it's not a 4010?
Old Jan 25, 2008 | 08:23 PM
0Speed Hound
Former Vendor
You're right it's 4010. It's the one with the cast on bowls but the top plate/air horn covers all that up.
Old Jan 25, 2008 | 10:18 PM
noonie's Avatar
noonie
On the airhorn you should find numbers similar to these to tell you exactly what it is and the supplied jet sizes.
The 4010 and 4011 were both the same style.
They are a copy of the old Ford Autolite 4100 carb from the early 60's and really are one of the best carbs ever made, they just didn't go over well with the perf crowd and Holy discontinued them and support for them.
Other than the top gaskets you can make the other consumable parts fit. Jets are interchangeable.
They are made of aluminum so they polish up nicely.
They also tend to be a little rich at idle and I had to drill out the air bleeds a little.
There is a book, you can find on ebay and also the kits.
84010 600 (F)67,(R)75 6.5 4010
84010-1 600 (F)67,(R)75 6.5 4010
84010-2 600 (F)67,(R)75 6.5 4010
84010-3 600 (F)63,(R)75 6.5 4010
84011 750 (F)75,(R)75 6.5,6.5 4010
84011-1 750 (F)75,(R)75 6.5,6.5 4010
84011-2 750 (F)75,(R)75 6.5 4010
84011-3 750 (F)73,(R)75 6.5 4010
84015 800 (F)64,(R)90 6.5,6.5 4011
84015-1 800 (F)64,(R)90 6.5,6.5 4011
84015-2 800 (F)60,(R)90 6.5,6.5 4011
84015-3 800 (F)60,(R)90 6.5,6.5 4011
Old Jan 25, 2008 | 10:30 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Do a search at Summit for parts.
Best thing I can say about them is that they are light
Old Jan 25, 2008 | 10:52 PM
0Speed Hound
Former Vendor
Awesome info guys! I do appreciate it. First time I pulled the air cleaner off the carb I sat there scratching my head. This is the only car I have ever seen with this carb on it. The car is running very rich at idle and is not very crisp throttle wise. I'm going to be going through the usual check points to figure this out, but I was really worried about getting the internal parts if I needed them. I couldn't find anything in my Holley catalog.
Currently there is no choke on the carb which doesn't help matters. Plan is to install an electric so the customer doesn't have to deal with a manual. It's his wife's car anyway and she doesn't want to put up with pushing and pulling a ****.
Thanks guys.
Old Jan 25, 2008 | 10:53 PM
0Speed Hound
Former Vendor
What's wrong, not a fan? Don't be shy about it if you have some insight on it. I did a google search and some people were praising it but never got into detail on internals.
Old Jan 25, 2008 | 11:01 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I had a flooding problem with mine, seems they didn't like much fuel pressure above 6lbs, but that may be fixable with replacement needle/seats. I used both the 4010 600 and the 4011 750 spread bore . The 4011 worked the best.
But I when I replaced it with a 600 cfm 4150 it ran like a different car
Old Jan 25, 2008 | 11:28 PM
noonie's Avatar
noonie
Mine is a spreadbore, mechanical secondary, and it will go back on one of these days.
Put it on years ago when Florida started emmisions testing. Remember that I had to take it apart over 20 times to jet, drill etc to get it originaally set right, but was wll worth it. Ended up passing the yearly emisions with flying colors and kept it on a daily driver for over 10 -15 years with no issues. That design bowl won't leak. Also has annular boosters. Did use only 4psi pressure with it.
With the mechanical secondaries, you could feel with your foot when the secondaries would quick in, but you could also cruise the interstate on the primaries alone at 75mph.
A noticeable improvement over a proper qjet and the fuel economy of a spreadbore.
Old Jan 26, 2008 | 04:37 AM
rpoL98's Avatar
rpoL98
I had one of these. I had a problem with the top cover paper gasket leaking fuel when the car was parked at a severe sideways angle. unfortunately that describes my driveway, so I had to take it off and replace it with the traditional-type holley.
I was kind of disappointed because I had boughten two of these, because the design sounded really good. one square bore, one spread bore.
I wasn't running a fuel pressure regulator, but the fuel pump was the original GM pump for the Quadrajet. Maybe the fuel pressure was marginally too high for this design.
anyways, that's all history now.
Old Jan 26, 2008 | 08:08 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Memories are returning as to why I had less than positive experiences.....the first time I attempted a jet change and removed the top cover all the screws were cross threaded and brought the threads out with them
Old Jan 26, 2008 | 12:07 PM
0Speed Hound
Former Vendor
Well, this one I have here is a 4011-1. Car is just a mild cammed and header 350. No wonder it's running rich.
Is there a source for the top plate gasket?
Old Jan 26, 2008 | 01:22 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Like I said Summit has a bunch of those carb parts....
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 26, 2008 | 04:28 PM
0Speed Hound
Former Vendor
I forgot. thanks.
To Holley 4110 help
