VB&P Spring Carrier Torque?
Old Jan 26, 2008 | 05:06 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Default VB&P Spring Carrier Torque?
Anybody know what the torque is on the carrier? The torque spec sheet doesnt list the carrier. They are just Gudentite right now. I cant get the rear two bolt to 35 ft lbs before the plate starts bowing.
Old Jan 26, 2008 | 05:29 PM
sperkins's Avatar
sperkins
63-77 / 40-45 lbs ft.
78-79 / 40/45 lbs ft.
80-82 / 45-50 lbs ft
With car on ground, re-torque center mount bolts.
Old Jan 26, 2008 | 05:31 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
thanks, I had it on the ground when I torqued all the rest of it up. Got it back in the air now to begin installing the exhaust. One of the factory books had it a 65 lbs, and I knew there was no way the carrier was going to take that without pulling the plate up and out.
To VB&P Spring Carrier Torque?
