Engine I.D. help needed.
Old Jan 26, 2008 | 07:41 PM
KENS78SILVERANNIV's Avatar
KENS78SILVERANNIV
Default Engine I.D. help needed.
I'm looking at a casting #3858174 on the rear of the block.
Heads have a casting #3917291.
What do we have here?... Thanks.
Old Jan 26, 2008 | 07:46 PM
Durango_Boy's Avatar
Durango_Boy
The engine block is a 327 CI from '64-'67, and has 2 bolt mains.
The heads are from '67-'68, from either a 302, 327, or 350. They are camel hump heads, with no accessory holes and have 64cc chambers.
Old Jan 26, 2008 | 07:53 PM
KENS78SILVERANNIV
Looks like someone's rebuilt this one. Not a bad set up. Thanks
Old Jan 26, 2008 | 07:54 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Here's a good link for checking.
http://www.mortec.com/castnum.htm
Old Jan 27, 2008 | 09:23 AM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
It's what & where I use to ID blocks & heads.
To Engine I.D. help needed.
