Hello,
I dont have the answer for you on this, but it is a common occurence. I think that as you get more answers to your question you will find that this is pretty common.
My cars do the same thing, and I think it is usually the left first, then the right goes down.
Hello,
I would have a look at the entire system to make sure there aren't any other little problems. I agree with everyone that it is probably your servos but I had to fix a cracked T connector and replace the filter and check valve as well as replace the servos. Now the lights work pretty good. The little parts are cheap but are just as important for a correctly functioning system.
