Holley Question about Secondaries
Old Feb 1, 2008 | 09:14 AM
spedaleden's Avatar
spedaleden
Default Holley Question about Secondaries
There is a small screw at the bottom of the carb by the sendondary control rod. Is this the screw you turn to open the secondaries a bit, per lars carb sheet?
If so, do you have to take the carb off to do this or can you get to it with a small screwdriver while on the car?
Thanks again
Old Feb 1, 2008 | 10:02 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You initially have to access if from the bottom, so you have to remove carb the first time.
Best way is to remove it and reinstall in the the other way so the screw slot is on top and you can adjust it without removing carb next time.
JIM
Old Feb 1, 2008 | 10:11 AM
spedaleden's Avatar
spedaleden
JIM
Thanks Jim
Wouldn't you think the manufacture would install the screw from the top, or is this there way of makeing sure you don't mess with it.
Old Feb 1, 2008 | 10:15 AM
lars's Avatar
lars
Yes, that's the secondary idle speed adjustment screw that I refer to in my setup paper. The BG carbs have the screw accessible from the top - Holley has a conversion kit for doing the same thing. Without the conversion kit, you have to take the carb off to do the setup correctly - I frequently remove and install a carb 3 to 4 times when I do the setup testing on Holleys in order to balance the idle speeds just right...
Old Feb 1, 2008 | 10:23 AM
spedaleden's Avatar
spedaleden
Thank you sir. I am going to my jegs cat ot order. I take it this is it.
http://www.jegs.com/webapp/wcs/store...10002_71952_-1
Old Feb 1, 2008 | 11:28 AM
lars's Avatar
lars
That would be it. Note that it cannot be used if you have a choke on the carb, and I don't think it's compatible with vacuum secondary carbs.
Old Feb 1, 2008 | 04:51 PM
spedaleden's Avatar
spedaleden
I have Vacuum Secondaries and a Automatic choke. I did see a auto choke in the instructions but no secondary vacuum. I tried what Jim suggested by rotating the screw and I know have both primary & secondary equal. I don't see this as being a problem.
Any word of advice
Old Feb 1, 2008 | 05:47 PM
lars's Avatar
lars
Once you have set the primary and secondary idle speeds to obtain equal airflow through both ends of the carb with an acceptable idle speed, there is no need for further adjustment - what little adjustment needs to be done can be done with slight movement of the primary side idle speed screw. So if you have it set, there really isn't an issue with secondary idle speed screw access. Good job setting it up right - that's the way to do it.
Old Feb 1, 2008 | 06:58 PM
spedaleden's Avatar
spedaleden
As always thanks for the time!
To Holley Question about Secondaries
