engine wont turn off
Old Feb 2, 2008 | 11:28 AM
bloater's Avatar
bloater
Default engine wont turn off
I have a mind boggling problem.Today I have started the engine in my 1980 vette for the first time since pulling the body off 12months ago to restore the chassis.(90% back together now).
Here's the problem.I turned the engine off by the ignition switch and it continued to run.OK I thought,possibly a bad or wrong connection keeping the system live.I quickly disconnected the battery thinking no power to raise a spark at the plugs, engine will stop running,right?. WRONG!!!!!. It continued running with battery removed and did not stop until i caused it to stall by disconnecting all the spark plug leads.
Someone may have a logical explanation for this and a simple fix, but at the moment I am baffled. To me this is an impossible scenario. No battery power = no spark to ignite fuel.any suggestions?????
Old Feb 2, 2008 | 11:34 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Engine running, no battery ? sure you don't have a wire wrong going to the alternator thats the only thing that can still produce current after the battery is disconnected, I believe
Old Feb 2, 2008 | 11:50 AM
'75's Avatar
'75
The batterys only purpose is to store power in order to start the engine and to provide power in case there is a intermittent load larger than what the alternator can suppport. That being said, there is no reason that the engine should turn off just because the battery is disconnected. On an engine with HEI, the power to the dizzy must be interrupted. you have wsomething wired up wrong. check with the ign switch turned on, engine not running, to see if there is voltage at the distributor power wire (large red wire that attaches to the drivers side of the dist.) check the same with the ign switch off. Should be 12 volts with switch on and 0 volts with switch off. If those are correct go ahead and start the engine then turn it off. If it will not die, then the alternator is somehow feeding the ign circuit. To get it to turn off simply disconnect the red wire from the dizzy. Next try unplugging the alternator plug and try it again.
Old Feb 2, 2008 | 05:00 PM
BKbroiler's Avatar
BKbroiler
Good explanation and advice.
Old Feb 2, 2008 | 05:04 PM
ENG40's Avatar
ENG40
If your battery cable to the starter is touching the 'R' terminal on the solenoid it will keep power going to the distributer and the engine won't shut off.
Don't disconnect the battery when the engine is running, it's bad for the alternator diodes.
Old Feb 2, 2008 | 05:05 PM
RunningMan373's Avatar
RunningMan373
Car was running on alternator, & ignition switch isn't functioning correctly
Old Feb 2, 2008 | 07:16 PM
bloater's Avatar
bloater
thanks for advice,I will check all of these and post results
To engine wont turn off
