Removable Crossmember Best Design
Old Feb 4, 2008 | 07:19 AM
sgrfred's Avatar
sgrfred
Default Removable Crossmember Best Design
ok...i think i was asking the wrong question yesterday ...what i need to know is what is the best removeable crossmember design you guy have seen over the years....strictly for the original 4 spd at this point thanks, fred
Old Feb 4, 2008 | 08:52 AM
livelotus's Avatar
livelotus
You beat me to the same question.
Old Feb 4, 2008 | 09:17 AM
OzzyTom's Avatar
OzzyTom
This was fabricated for a recent tremec installation..... allows easy access for future removal of trans.
Old Feb 4, 2008 | 09:53 AM
68 NJConv 454's Avatar
68 NJConv 454
I like the above design, thats all you really need.
Once I get bored I want to do something like below to make the entire trans xmember removable. This isn't the muncie but its a neat looking xmember.
First time I have to pull my trans I'll do it like the pic above.
Enjoy.....
Old Feb 4, 2008 | 01:52 PM
Solid LT1's Avatar
Solid LT1
Put the factory auto Xmember in for a clean installation.
Old Feb 4, 2008 | 08:26 PM
MN80Vette's Avatar
MN80Vette
The stock '80-'82 crossmember is removeable. Here's a pic of most of my stock removeable crossmember modified for true dual exhaust. That's a stock BW Super T-10 mounted on it to the left.
Old Feb 4, 2008 | 09:34 PM
sgrfred's Avatar
sgrfred
Default rem x-member
back again...thanks for the info...any others? ttt, fred
Old Feb 4, 2008 | 10:31 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Did you check out this thread from awhile back?
Crossmember
Old Feb 4, 2008 | 10:43 PM
sgrfred's Avatar
sgrfred
Default old post
thanks bullshark ...thats awesome! ...i think i have my solution! ..fred
Old Feb 4, 2008 | 10:51 PM
84rzv500r's Avatar
84rzv500r
I too borrowed form the work here... To mount a ROD 6 speed...
I used my cnc plasma cutter and made 4 bolts per end... verticals are 3/8 mild steel tube is 2x3x0.125 rectangular...
I also W braced the trans cross member to the frame rails with 1x2 and to the rear member with 2x2 and mounted the seats via standoffs to this subframe.
Old Feb 5, 2008 | 05:40 AM
aworks's Avatar
aworks
I just put the stock auto. crossmember on my road race project this past week end. The body is off but even with it on it's a simple install. I also did one in our 74 like OzzyTom did. I did it for a Richmond 6 speed. Either way is pretty simple. I'll never understand why GM did not do this in 63 when they stared this frame. Pulling a trans is a snap without that crossmember in the way.
Old Feb 5, 2008 | 06:46 AM
mrvette's Avatar
mrvette
I find the exhaust is more of a PIA to work with than anything, so to stop leaks and ticking, I had it welded up years ago....got tired of getting it rewelded if I had to do any tranny work...due to that damn crossmember...so....
My car being a muncie car originally, years ago I cut the crossmember about 3" from each end....got some angle iron welded on to position it when going back in, and hole from topside allowing to slip back to remove...with a grade 8 1/2 inch diameter bolt and nylon nut on it going fore/aft.....that holds it fine on each side....
so for the middle there still were those two holes in there capturing the pipes, the cure is to cut the bottom of the loops out and back at an angle, the fill in the open channel with 1/8 inch steel plates then put a 1" wide plate down the center of the top loop oriented fore/aft....
then cap the plate with steel to the sides you just closed up...making an up and over reinforced arch out of the loop....it comes down about an inch or so from the original height, but the pipes hang maybe 1/2 inch lower...so what....
i'ts cheeeeep, and it works, just wish I had done it years ago instead of last year....
Old Feb 5, 2008 | 08:36 AM
69vettester's Avatar
69vettester
Heres complete Inst. for Rod 6.
http://69vettester.com/richmond.htm
Old Feb 5, 2008 | 09:00 AM
68 NJConv 454
Whats a "W" brace?
Old Feb 8, 2008 | 11:30 AM
84rzv500r's Avatar
84rzv500r
triangulation of transmission xmember to frame rail and new frame sections running either side of the driveshaft that carry the seats and the drive shaft saftey loop.
these form a pair of W's or M's under each seat... fundamentally the same as a X brace but modified to support the seats via the frame, the drive shaft saftey loops, and the light weight traction bar setup.
Old Feb 8, 2008 | 01:36 PM
Richard454's Avatar
Richard454
I like the removable crosemembers I've seen here...But getting my welder buddy to come to my house...or get the car to him-Just hasn't happened.
So- I thought about this design-can easily be done w/o any welding to the car-Just a cut and drilling. Take the frame piece to his shop and he can weld it up in no time.
What do you think?
Old Feb 8, 2008 | 02:24 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Slick idea
To Removable Crossmember Best Design
Old Feb 9, 2008 | 02:15 PM
Richard454's Avatar
Richard454
Originally Posted by yellow 72
Slick idea
Thanks.... I post pics when i do it.
Richard
Old Feb 9, 2008 | 03:59 PM
willem wallace's Avatar
willem wallace
Default crossmember
I have to agree with Mr Vette that the exhaust removal can be as bad as the transmission. I did some mods to my crossmember, to facilitate one piece system removal. I have not tested my modification, under engine torque, as my restoration is not complete, but I am confident it will be secure. I have saved detailed pictures to my hardrive, if anyone cares to take a look, or perhaps post them on the site to help guide others.
Old Feb 9, 2008 | 11:35 PM
CorvetteDave01's Avatar
CorvetteDave01
Here is mine with a Tremec TKO.
