Compression test
Old Dec 2, 2001 | 07:47 PM
69ttop502's Avatar
69ttop502
Default Compression test
Is it OK to do a compression test on a cold engine?
Old Dec 2, 2001 | 07:48 PM
lars's Avatar
lars
Default Re: Compression test (69ttop502)
You can, but it won't be as accurate or meaningful as a comp test on an engine at operating temp. It will, however, reveal gross problems.
Old Dec 2, 2001 | 08:29 PM
Jvette73's Avatar
Jvette73
Default Re: Compression test (lars)
Pull all the plugs for the test to reduce drag on the starter and get the engine spinning faster. Prop the throttle wide open as well.
To Compression test
