Swapping differentials..
Old Feb 6, 2008 | 10:40 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Swapping differentials..
Pulled out my Tom's 4.11 posi tonight as I'm replacing it with a 3.73 spool which I'm trading with Red79Vette454.. I'll have to have Van Steel transfer the pinion yoke tomorrow (the pinion yoke on the 3.73 spool is for 1330 series u-joints and the one on my 4.11 posi is 1350 series as my driveshaft u-joints are 1350 series) as I don't have a impact wrench to get the pinion yoke nut off... If all goes well, the spool should be in tomorrow evening!!
Here are the differentials.. My 4.11 posi diff on the left and the 3.73 spool unit on the right..
Old Feb 7, 2008 | 02:14 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Olivier, with the power levels your getting into IMHO this should prove to be a good move, particularly the spool.
Old Feb 7, 2008 | 05:30 AM
mrvette's Avatar
mrvette
Glad you got two mules to help hoist them things outta that trunk....
talk of a ball buster....
9 second quarter, I been following you escapades there, doing fine man, just fine as wine....
Old Feb 7, 2008 | 07:12 AM
GrandSportC3
It is actually required to run a spool if you run below 10.0.. I've never raced a car with a spool before, so we will see if the car reacts any different..
Old Feb 7, 2008 | 07:13 AM
GrandSportC3
The differentials aren't all that heavy.. The old posi is 107 lbs and the spool unit is 99 lbs..
I need the lower gear to run a 250 shot of nitrous.. Otherwise, I'd run out of RPM's...
Old Feb 7, 2008 | 07:38 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Double check the overall width of the axles. Those flanges look a lot thicker on the spool one....might be a factor with halfshaft length if you use old ones. Of course might be fine if the spool has the flanges pulled inward a like amount.
Good luck...it's going to like the 3.73's when you spray it.
JIM
Old Feb 7, 2008 | 08:30 AM
GrandSportC3
JIM
Already did all the measurements.. The 4.11 posi is 13 inches from axle to axle (on the outside) and the 3.73 spool setup is 12.5 inches (actually narrower by 1/2 inch) BUT the spool setup comes with 1/4 inch spacers each side which makes it identical width of the posi setup!
Old Feb 7, 2008 | 02:29 PM
427Hotrod's Avatar
427Hotrod
Cool....they did look like they were closer inward...but couldn't really tell. Just trying to head off heartache!!
Going racing this weekend? It will be neat to see a back to back motor pass against the 4.11's to see if it loses much. Maybe a tenth at the worst? The lighter spool etc might even cancel it out and be equal.
JIM
Old Feb 7, 2008 | 02:41 PM
GrandSportC3
JIM
I'm planning on racing on Sunday..I'll make 1 or 2 engine passes and then flow the nitrous system with the 100 HP jets.. Will make a pass or 2 with the 100 shot but won't go with the bigger shot yet as I'm still using the Radial slicks and they are swaying really bad above 125 mph.. I'll feel safer once I'll get my new wheels so that I can install my new 28 x 10.5W - 15 ET Drags.. I know that I will lose a few 100's in the 1/4 mile due to the bias-ply design but I will get better high speed stability..
The spool isn't all that lighter.. Weighted both differentials and the old one weighted in at 109 lbs and that was with 2 qts of posi fluid in it and the strut rod mount attached.
The Spool unit weighted in at 99 lbs dry and without the strut rod mount. Adding about 5 lbs for the fluid and 2 lbs for the strut rod mount, there's maybe a 3 lbs difference.. Not a whole lot.. I expected more..
Old Feb 7, 2008 | 11:38 PM
GrandSportC3
UPDATE!! Spool Differential is installed.. Going for alignment on Saturday. Should get my new wheels tomorrow and I already got my 28 inch tall slicks (ET Drag 28 x 10.5W - 15)
Old Feb 8, 2008 | 06:53 AM
red79vette454's Avatar
red79vette454
What kind of wheels you getting?
I can't decide if I like the Aluma stars or the Magnum 2.0 for our new setup. Either one will probably be 15x15 or 16x15 and have beadlocks.
Old Feb 8, 2008 | 07:11 AM
GrandSportC3
I bought some New Old Stock Cragar Super Lites (set of 4) which are just about identical to Weld Drag Lites...
I will keep 2 sets of wheels.. One with 28 inch tall slicks for engine only or small shot runs and the 2nd one with taller tires for the full 250 shot (I might go with GoodYear 29 x 11 - 15 Dragway Special tires). Right now I have the Hoosier Radial slicks on there (29.5 inch tall)
The Magnum 2.0 are nice wheels but they are very expensive.. If I'd buy new wheels, I'd actually go with MT ET Drag wheels. Those are the lightest that I know..
Old Feb 8, 2008 | 08:00 AM
comp's Avatar
comp
Old Feb 8, 2008 | 09:07 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
I am running a 33 x 16 tire on a 15 in. rim....beadlocks $$$$$$$$$$$ !!!!!!!!
I am considering them also. I need to find a wheel sponser !
You will like the spool Ollie...cept when you have to push the car around the slightest of a corner.
Old Feb 8, 2008 | 09:37 AM
GrandSportC3
Turning any corners will be especially painful with the radial slicks. Once I'm back to bias-ply, it should be a little better.
Old Feb 8, 2008 | 10:47 AM
69 N.O.X. RATT
Have you ever tried to push a car around a corner that has a spool? Trust me it does not matter what kind of tire is on it....the car stops dead in its track as soon as you turn the steering wheel. My car weighs 2400 lbs with me in it and it takes three or four guys to push it around a semi tight turn.
Old Feb 8, 2008 | 10:53 AM
GrandSportC3
now that'll be fun
Hope that I won't need to push it too much
To Swapping differentials..
Old Feb 8, 2008 | 11:16 AM
69 N.O.X. RATT
now that'll be fun
Ha ha...it is a race car....you will be pushing it a lot more than you want !!
Old Feb 8, 2008 | 11:20 AM
GrandSportC3
I did my share of pushing already
Old Feb 8, 2008 | 01:45 PM
TheSkunkWorks
I agree with 69 N.O.X. RATT. It's been a few years since I dealt with that, and I had almost forgotten about how much harder it is to push a car around with a spool. I've done my share of Austin Powers type multi-point turns, as the term "tire scrub" doesn't even come close to describing it...
...still, IMHO it's the right thing to do once you get quick, rule or no.
