What Carb gasket?
Old Feb 7, 2008 | 01:05 AM
Wisp's Avatar
Wisp
Default What Carb gasket?
Hi...
Just installed a new intake.
My carb gakset do not seem to fit...
Intake: Edelbrock Performer.
Carb: Holley Street Avenger 670.
The gasket seems to be covering alot of the intake...
Any advise?
Best regards Søren
Old Feb 7, 2008 | 02:09 AM
73StreetRace's Avatar
73StreetRace
I think you will find everything you need here ( need adobe acrobat to view ) :
http://www.mr-gasket.com/pdf/carb_fuel_accessories.pdf
Old Feb 7, 2008 | 03:50 AM
Wisp's Avatar
Wisp
Thanks for the info....
But there have been some discusion about using a open gasket, 4 hole or 2 hole gasket...
Any ideer about this?
Søren
Old Feb 7, 2008 | 05:14 AM
Matt Gruber's Avatar
Matt Gruber
i recommend the thick 4 hole type. see link in my sig.
Old Feb 7, 2008 | 05:22 AM
Wisp's Avatar
Wisp
Link wont work...
Old Feb 7, 2008 | 06:57 AM
Matt Gruber
holley 108-51
the 108-58 should work, but it says model 4180
link worked for me.
Old Feb 7, 2008 | 07:47 AM
Wisp's Avatar
Wisp
This?
Old Feb 7, 2008 | 09:30 AM
lars's Avatar
lars
The open gasket in your first photo works just fine for the Holley installation. It's not going to match the manifold because the manifold is set up for both a Q-Jet and a square bore carb application. But that gasket is correct for your carb mounting application and will work just great.
Lars
Old Feb 7, 2008 | 10:21 AM
redwingvette's Avatar
redwingvette
Is there a reason to run the thick gasket on the aluminum manifold. I have one now but i would like a little more clearance for the air cleaner.
Sorry, I didn't mean to hijack your thread, just looked like a good time to ask.
Old Feb 7, 2008 | 10:53 AM
Wisp's Avatar
Wisp
Lars
Thanks Lars...
Then lets hope that I get rid of that BAD stumble i have....
Old Feb 7, 2008 | 11:27 AM
Matt Gruber
the 1/4" helps stop heat soak boilover.
the 4 hole improves mpg and low end tq.
http://community.webtv.net/MATTGRU/carb
lars is way behind the curve on this topic
Old Feb 7, 2008 | 11:57 AM
lars's Avatar
lars
Yeah, you bet. That's why I have an instrumented test engine set up in my workshop where I test parts, components and systems on almost a daily basis...
To What Carb gasket?
